Conexant AC-97 Audio HELP, PLEASE!
  1. Posts : 8
    Windows 7 Ultimate 64-bit
    Hello everyone,
    I hope everbody's doing well. Please, I do really need your help to fix a problem with my Sound Card ''Conexant AC-97 Audio'' I have recently insalled Windows 7 Ultimate 64-bit and it seems to be working fine, though this particular issue with the sound card drivers. I have tried a lot starting by the solutions suggested by users on this forum but never gotten to fix the problem.
    Here are two photos I have taken from a screan scan which will show you exactly what's wrong, and I know that many people have the same issue ...
    http://img683.imageshack.us/img683/8359/photo1r.jpg
    http://img706.imageshack.us/img706/2106/photo3gz.jpg
    I do highly appreciate any help on this, and thank you very much in advance ...
  2. Posts : 8
    Please help! I am going crazy here! I've tried all that I know so far but nothing worked. I do really need your help guys ... Thanks!!!!!!!!
  3. Posts : 3,960
    W7 x64
    All you appear to need to do is install the drivers...
    Read the following, inparticular posts one and eight...
  4. Posts : 8
    Thank you for your kind reply, I have followed the instructions BUT unfortunately no positive results Here is a photo that shows what happened after doing those steps ...
    http://img33.imageshack.us/img33/3540/resultw.jpg
  5. aem
    Windows 7 Ultimate 64Bit
    It looks like you need drivers for those device with yellow exclamation marks. Can you provide the PCI IDs for those? Hows how to get the info.
    Driver selection for your Hardware devices.
  6. Posts : 8
    Thanks alot for trying to help out with this complex issue, here are some pics will show you what is going on exactly with my machine!
    http://img696.imageshack.us/img696/3299/88897254.jpg
    http://img43.imageshack.us/img43/5340/26879511.jpg
    http://img145.imageshack.us/img145/6431/38499496.jpg
    http://img200.imageshack.us/img200/2338/96358679.jpg
  7. aem
    In the Details tab, under Property, select Hardware ID. You haven't doen this.
  8. Posts : 8
    aem said:
    in the details tab, under property, select hardware id. You haven't doen this.
    pci\ven_8086&dev_266e&subsys_3082103c&rev_03
    pci\ven_8086&dev_266e&cc_040100
  9. aem
    Have you tried installing this?
    PC HD-Audio Modem Combo
  10. Posts : 8
    Thank you very much guys for trying to help out, I appreciate it :)
    I last thing I tried and it's seems working fine is this method I found at another website and I want to share with the others who might have the same issue and thank you once again :)
    Download the "Conexant AC97 Audio Driver for Microsoft Windows Vista (64-bit)" from http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-51288-1
    installing it regularly didn't work but you can make a trick.
    1. first, try to install it normally with the driver. it will probably fail but it will be extracted in C:\swsetup\SP35558 by default
    2. open the .inf file and locate
    [Conexant.NTamd64]
    %*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD,PCI\VEN_1002&DEV_4370&SUBSYS_308B103C
    %*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD_DF,PCI\VEN_1002&DEV_4370&SUBSYS_308E103C
    3. add this line to it
    %*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD,<x>
    <x> can be found by going to the device manager, open the unrecognized audio device's property page, select "Details" tab, and select "Hardware Ids" from the Property combo. One of the listed strings should be <x>. it was the top one in my case.
    In my case <x> was PCI\VEN_8086&DEV_266E&SUBSYS_3082103C&REV_03
    so it eventually looked like:
    [Conexant.NTamd64]
    %*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD,PCI\VEN_8086&DEV_266E&SUBSYS_3082103C&REV_03
    4. now install the driver manually through device manager. It installed as "Conexant AC-Link Audio" which i find weird since it first was listed as "Conexant Realtec AC-97".
