Windows 7: Realtek - sound not working right.
26 Dec 2009   #1
onyx
I just installed windows 7 (clean). I did not have sound at first. After downloading the realtek drivers...the sound did start working by switching from stereo to 7.1 speaker (in the realtek HD audio manager) .....so the surround speakers work but the front left and right do not, and thats all i have (the front left and right). Also it sounds like an echo (almost like a sound effect) but there is no sound effect selected.
I did try disabling/re-enabling, switching the in/out-put around, restarting, and i did download all the driver packs.
Thanks so much if someone can help me, hope i explained it all ok. I also added 2 pics to this so you can see what i mean. =)
This first pic is when my sound does not work in the realtek manager, and the 2nd pic is when it does work (with an echo)
Realtek - sound not working right.-realtek1.png   Realtek - sound not working right.-realtek2.png
26 Dec 2009   #2
Jonathan_King
Windows 7 Professional x64
Hello, Welcome!
Try uninstalling the Realtek Manager from Programs and Features. Could you then post a screenshot of your Control Panel>Sound window?
Thanks,
~Jonathan
26 Dec 2009   #3
onyx
Tyvm. Here is the new screen shot. =)
26 Dec 2009   #4
Jonathan_King
Thanks. Can you right-click on Speakers and select Configure?
26 Dec 2009   #5
onyx
here it is ...
26 Dec 2009   #6
Jonathan_King
Does the sound work if you set it to Stereo or Surround 7.1?
26 Dec 2009   #7
onyx
When i put it on 7.1 the SL and the SR work.
26 Dec 2009   #8
Jonathan_King
Play around with the settings. What setting produces the best results?
26 Dec 2009   #9
onyx
The 7.1, but i cant hear a video on youtube now (i can just hear the test). With realtek i would put it on 7.1 but there was an echo from videos.
27 Dec 2009   #10
onyx
After I tried everything, I reinstalled windows 7 and installed the driver and codec's but it still didn't work. Then, i was fixing my cords up for the speakers and i tried to plug it in the front, that didn't work either. Sooo when i plugged them back in to the back of the tower it started working!!! I'm sooo happy i finally got it fixed bc i was about to go back to xp lol. I'm not happy that i cant help other people on here with the same problem bc i really have no idea how they started working? - Thanks for your help Jonathan =)
Realtek onboard audio stops working, no sound
Hi all, Recently moved apartments, and as part of that I shut down and packed up my computer. Upon getting it set up at the new place, I found that 1) the rear panel audio was now displaying "Not plugged in" and not producing sound, 2) the front panel headphone jack was no longer working, and 3)...
Realtek network card not working with external sound card installed
Hi all, I recently bought a relatively expensive sound card on Amazon and after the second boot of my PC with the card installed and working my on board LAN card decided to not work throwing error: "This device cannot start. (Code 10)" The card IS enabled in the BIOS and I HAVE disabled the...
Hardware & Devices
Realtek/Windows Sound not working but detecting devices.
As the title suggests, my on board sounds, seem to have failed, every time I boot, I get a Windows Troubleshooter telling me that the audio devices and services are not enabled or started, the troubleshooter fails without any errors to report (will grab a screen of this when I can) Here is a...
New MSI mobo with realtek sound not working
Hi i have a new MSI mobo H61M-P31(G3) that i used to replace a Dell mobo(unknown model) everything fit right and all drivers installed right but still have no sound. I'm not sure if this is due to a driver conflict because i did not reinstall windows or if it is a fault on the board. Yes i have...
Drivers
realtek ac97 no sound,but shows its working
Knowing my luck,I have overlooked a setting,but either way my sound is not working,i recently installed win 7 build 7100,and my onboard sound card is not working,my sound properties and volume control shows it is working but there is no sound coming out,ive checked the volume and all the stuff that...
Twitter Facebook
