No Sound After RAM Upgrade
My PC
OS : MS Windows 7 Ultimate 64-bit
CPU : AMD Athlon 64 X2 5600+
Motherboard : ASUSTeK M2V VIA K8T900
Memory : 2x1GB Corsair Dual Channel DDR2 800Mhz (5-5-5-18)
Graphics Card : 512MB Radeon X1650
Sound Card : Sound Blaster X-Fi Elite Pro
I have had no problems, until now. This Christmas i got 2x2GB Dual Channel DDR2 800Mhz. I installed them and booted up windows 7. Everything seemed fine, until i noticed there was no sound! I investigated further to find that no sound was being processed through my feedback monitor. It was also interesting to see that WMP refused to play MP3s, and album art would flicker. VLC can play MP3s, and also CDs work but of course no audio.
So next i have Tried all the different possible combinations of ram. The only working configurations apart from the original was one of the new sticks on there own, or also one new and one old. All the other configurations render the sound problem. I have also swapped ram with another computer to check the ram, and it works fine on the other computer, and the ram from that PC doesn't work on mine. I have goggled far and wide to find a solution and cannot find anything even remotely similar. i have also updated my BIOS in a attempt to correct the problem, and i have run a diagnostic of my sound card with the bundled software, yet it says everything is fine.
Any ideas, solutions or any kind of input would be greatly appreciated.
Thanks for your time
-Xisuma
