Windows 7: SB X-Fi Xtreme Audio driver problem with windown 7
29 Dec 2009   #1
Smopot75
windows 7 home pro
Hey all,
I recently installed windows 7 on my computer and everything worked well accept my sound didn't work.
I put in my Creative SB X-Fi Xtreme Audio driver CD and tried to install them but I ended up with a BLUE SCREEN! about 70% into the installation
I reaserched that many people have almost the same problem with SB X-Fi xtreme audio drivers and windows 7.
Can any one give me any suggestions of what could be the problem.
Smopot
29 Dec 2009   #2
DaveHMCFC
I'm having a very similar problem!
I have the same card, but mp3's play fine. Even some videos in Youtube play ok. It's all other videos on other websites that aren't playing sound for me.
I get a horrible, barely audible noise, or sometimes a scratchy whiney noise.
It's been doing my head in now for two days... help please!!
29 Dec 2009   #3
fireberd
From posts on the Dell users forum, the SoundBlaster needs Windows 7 drivers. It seems the Vista drivers will not work (and the XP drivers definately will not work). There is a Beta driver on the Creative downloads and many have reported this works in Win 7 and it also corrects a noise problem on some systems with more than 3GB of RAM.
29 Dec 2009   #4
Smopot75
windows 7 home pro
well i the only problem i have is that the drivers will not get installed every time i do try to install it, IT WONT LET ME! errors and [email protected]#
29 Dec 2009   #5
DaveHMCFC
Right... i've finally managed to sort it!! (you've no idea how good this feels!)
The problem was simple in the end. In the "Audio Control Panel" Creative put in with the driver download, there is a setting where you state what type of speaker set up you have... ie 2.1, 3.1, 5.1 etc. It was set to 7.1, so i changed it to 2.1, and bloody bingo!!
Now i've never seen one of these bloody control panels before so didn't even know it was there until just a minute ago.
29 Dec 2009   #6
Night Hawk
W7 Ultimate x64/W10 Pro x64 dual boot main build-remote pc W10 Pro x64 Insider Preview/W7 Pro x64
The Creative site will see two updates one for the audio consolde launcher while the other is for the driver set. You will likely want the console since that also controls other things like the mixer, EAX effects, equalizer, etc. there.
The software disk that comes along with the card is outdated even for Vista there. It's the same as with many video cards. Which model XtremeAudio are you using there? The PCI or PCIe? For the pci model good for both 32bit and 64bit 7 and Vista 64, Creative Worldwide Support
For the PCIe model good for XP as well as Vista and 7, Creative Worldwide Support
Remember to click the "Show Details" link to the right to read the information on the card you go for there.
30 Dec 2009   #7
DaveHMCFC
It's all sorted now cheers.
30 Dec 2009   #8
Smopot75
windows 7 home pro
ok well i played around with windows 7 and dled over 10 different drivers for X-Fi Xtreme Audio
AND FINEALY GOT SOUND TO WORK
ALL IT TOOK WAS 10 WINDOWS UPDATES! w00t!
30 Dec 2009   #9
Night Hawk
Just in time for the New Year!
31 Dec 2009   #10
DaveHMCFC
Quote   Quote: Originally Posted by Smopot75 View Post
Nice one.
Lol.... always check Windows updates first though!
Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit. If you have any idea what can cause the issue please help, if nothing will work i will...
Creative SB x fi xtreme audio delay problem!
Hi, I've recently bought a creative SB x-fi xtreme audio, and no matter what update i do, I keep having delay problems( 0.5 to 1sec) when connecting my guitar through the mic/line entry....... To make things worse, the driver even crashes and all sounds get delayed, i mean even in windows media...
hello, i posted few days ago request for help in one thread from xfi but no help, so im starting new thread. so : i have SB X-Fi Xtreme Audio PCI OEM. can someone help me step by step what to do to enable the mic ? have following problems : cant find any useful drivers cause during...
Creative X-Fi Xtreme Audio Driver Problems
I recently installed Windows 7 on my computer and downloaded the new .90 driver for my "Creative Sound Blaster X-Fi Xtreme Audio" PCI. I can't seem to switch between the recording device "Microphone"(front Jack) and "Line-In"(Back). Also I tried downloading the driver package that includes the...
Creative X-Fi Xtreme Audio x64
Hello, my Windows 7 x64 (7100) found after a clean install new optional updates which included drivers for my soundblaster X-Fi Xtreme Audio. I also used the drivers I got with the cd and installed them on my system. Everything is working now except a few options. I get sound in 5.1, but when I...
Twitter Facebook
