Realtek HD mic detection issue
  1. Posts : 3
    Windows 7 Build 7000
    Hi guys
    I've a Macbook Pro with the Win7 build 7000 running on it. Everything works fine except the microphone detection of the Realtek HD adapter. the macbook pro only has 2 jacks. one for the headphones and the other should be the mic/line-in.
    By plugging in the mic from my headset, the realtek audio manager just shows me an input device instead of the microphone.
    The built-in mic from the macbook works fine, but I prefer using my headset for skype.
    Is there any workaround to fix this issue? how can i "tell" the realtek audio manager, that the plugged device is a mic?
    I already installed the lates realtek HD drivers (2.18) and tried to assign the mic/line-in manually over the registry (Realtek HD Changing Jack output reassignments ( FIX )), but nothing could solve this problem.
    here are some screenshots which are describing the issue. yes it's a german installation
    many thanks
    dumdidum
    Attached Thumbnails Attached Thumbnails Realtek HD mic detection issue-realtek.jpg   Realtek HD mic detection issue-winconf.jpg
  2. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Hi dumdidum and welcome to Se7en Forums
    Referring to your first image, right-click on the BLUE socket and select Connector Retasking...
    You should be able to set the appropriate option here.
  3. Posts : 3
    hi dwarf
    thank you for the fast response! when I try to right-click on the blue socket i just get the option "Audio Device Settings"...
    is there another way to open this setting screen?
    thanks
  4. Posts : 9,582
    Hmm... I only get the option Connector Retasking... with the front panel sockets, but not with the rear panel sockets. I do, however, get Audio Device Settings with both sets of sockets.
  5. Posts : 3
    mh seems like i have to wait for some new drivers from realtek.
    but thanks for the help!
