Help me in configuring my 4.1
  1. Posts : 10
    I have a 4.1 speaker(Logitech R20 2.1+2 Creative normal ones). The problem is that i am not getting the proper bass effect as my friends Logitech R20. He told that the settings may not be done properly. Mine is Realtek HD Audio. Pls help me in configuring it. Heres is the screenshot.
    Attached Thumbnails Attached Thumbnails Help me in configuring my 4.1-untitled.png
  2. Posts : 13,354
    Windows 7 Professional x64
    Hello guest,
    Try going into the Sound Effects tab in that window. That may have what you are looking for.
    ~Jonathan
  3. Posts : 8
    If your sound card support jack retasking, double click on blue output and check rear to front speaker...
