how u guy install win 7 64 bit?
i stuck at load driver b4 select drive to install windows.
how u guy pass the load driver step?
I imagine these instructions would work for me but when I try and run the sigmatel exe file I get an error code 110 saying it was not able to successfully unzip the file. Please help
Many thanks to- hyp36rmax ,
I spent 4-5 hours on net, not able to fix the above problem, finally i am done after reading to this post, nice solution post. keep helping.
Thanks again and thanks to the site admin.
With warm regards,
Rudra Narayan Garnaik
www.garnaik.com
With warm regards,
www.garnaik.com
One comment, DO NOT use the Dell Download Manager to download drivers. Download each driver you want directly (individually). The Download Manager has caused many problems.
Thank you very much... this solution worked perfectly on my Dell Inspiron 1420 with Windows 8!!!
