Need help with Sabrent SBT-SP6C No Sound Issue
  1. Posts : 8
    W7
    I purchased a SBT-SP6C which is on Microsoft's Windows 7 acceptable hardware list. I've installed it and downloaded the Windows 7 drivers fromthe Sabrent website. The device shows up in my system, but I get no sound. I know my speakers work because I hooked them up to an external source. I can hear some feedback when I unplug the jack.
    This is on my son's Dell 4600. Any ideas?
  2. Posts : 1,309
    Windows 7 Ultimate 32 bit
    Sound
    in sound properties make sure to select that device as playback device
  3. Posts : 8
    W7
    It is, it's the only sound device in the computer.
  4. Posts : 1,309
    Sound
    check all output jacks and make sure to select how many speakers your using the sound control area in 7 at least on mine is a little weird to figure out
  5. Posts : 1,309
    can you right click on the speaker icon and choose configure
  6. Posts : 8
    W7
    I tried each output jack on the card. I could hear static each time I disconnected and reconnected the speakers. I configured the sound card. Windows says the card is working fine. Still no sound.
  7. Posts : 1,309
    card may be faulty can you try it in another machine just to make sure
  8. Posts : 1,309
    are you using 32 or 64 bit windows
  9. Posts : 1,309
    Drivers
    it appears there are no 64 bit drivers that i can find
  10. Posts : 8
    W7
    I'm using 32 Bit. I e-mailed Sabrent and Jeff had me try and see if I got any different result on another PCI slot. I tried 2 other slots and had the same result...no sound. The weird thing is, I can go to the configurator and click the speaker to mute and un mute. I hear a noise when I do that.
    This is very frustrating because I only purchased this sound card because it was on Microsoft's website for compatibility. I purchased two for two different computers because the card I had in them were not on Microsoft's list.
