Windows 7: Volume not loud enough - how do I bypass volume limit?
26 May 2011   #31
Vertex
Windows 7 Ultimate 32 Bit, Windows Developer Preview, Linux Mint 9 Gnome 32 Bit
Buy a stereo headset with a stronger dB (decibel) output and you'll get a louder sound but be careful, loud music can impair your hearing. I learned this myself by frequently having max volume on my headset and playing drums quite often. Now, I felt I had trouble hearing what other people say sometimes. Or if you don't bother spending money, get a 5 in 1 speaker system.
By the way, Linux operating systems produce loud sound and by default, the volume is not even max. If you max a Linux's volume control, its 15-20% louder than max volume on Windows but Windows' sound quality is a bit clearer....anyway Linux's are louder with sound output. I use Linux Mint 9 and I seem to prefer it more when playing music like Mp3's or watching Youtube than Windows because its LOUDER definitely.
26 May 2011   #32
fseal
Windows 7 x64 Ultimate
Yeah, VLC can make the volume louder (Volume goes to 200!), but a lot of times that's at the expense of audio Quality. It's just amplifying the signal in software which then clips the peaks that are there and eventually flattens the dynamic range and destroys the SNR Though in an emergency, if you want to hear something that's very quiet, it comes in handy...
02 Jun 2011   #33
bitsmt
Windows 7 Professional x64
Imperfect1 response is in the right direction.
The Volume control requires drivers, which have the hard coded upper and lower limitations. Manufactures put this in place to prevent you from blowing your speakers or internal amplifier. It can be bypassed, using two options. Only ONE is a universal solutions.
Option 1: Check to see if you is the ODM (Original Design Manufacturer) for your computer. There may be a better driver. (I.E. Clevo, Compal, Quanta, Wistron...)
Option 2: Reverse engineer the drivers and determine how to edit the upper and lower limits. (Could be as easy as a registry edit or ini file mod).
Option 3: Install a Media Player (such as VLAN's VLC) that will allow you to bypass the upper limit.
Option three is the easiest.
How do I know?
1. If you ever had an M2400 with XP64 or W764, you'll find the M$ drivers provide louder volume control than the Manufacture ones.
2. There are news threads out there that show you how to edit the file in the drivers that alters the upper limit (sorry, can't remember the linky). I.E.: Search http://forums.laptopvideo2go.com.
Buena suerte!
P.S. VLAN has (advanced) settings that does let you go way, WAY beyond 200%. Not recommended.
06 Jul 2011   #34
kentucky777
Windows 7 Ultimate 64 bit
setup your loudness setting in your speaker in control panel heres the screenshot
06 Jul 2011   #35
xarden
Windows 7 Enterprise
I'm somewhat horrified to see some of the suggestions here...
Protect your equipment, and use an amp and some proper speakers.
07 Jul 2011   #36
fseal
Heh yeah, the REAL solution is to use externally amplified speakers....
I have to keep the volume on my studio monitors to about 25% or I'll blow my ears out. :)
09 Jul 2011   #37
DrToxic
Micro$oft Windows 7 Ultimate x64
I use optical out to my sound coversion box, and i've never had anything on my pc set below 100%... (though the self-amped speakers...different story)...
seriously, you want it louder? buy an amplifier and some bigger speakers...
Just dont forget, if you decide to go stupid on how big your getting, keep them away from your PC, the magnetic field will format your HDD for you.
"carelessness causes loss of data"
09 Jul 2011   #38
Zepher
Windows 7 Ultimate 64bit
Quote   Quote: Originally Posted by DrToxic View Post
You'd need a speaker with a very strong magnet and you would have to have the hard drive basically attached to the speakers magnet to cause any damage or data loss.
10 Jul 2011   #39
xarden
Quote   Quote: Originally Posted by Zepher View Post
Agreed.
If you hold a harddrive in front of a PA speaker cone, you'll be safe.
The only way you'l get any type of magnetic interference is if you hold the drive right up to the PA speaker magnet itself.
PA speakers are a massive overkill for a PC anyway, unless you plan on filling a hall or auditorium. In which case you wouldnt have the PC anywhere near the speakers anyway.
You're not wrong, DrToxic. But just a bit out of context
11 Jul 2011   #40
fseal
Used to be a big problem back in the old CRT days... Most studio monitors and larger computer specific speakers are magnetically shielded.
Though with LCDs it's not really a problem any more...
How to limit max. volume windows 7?
Hi, in Windows 7, I want to limit the maximum volume level that can be used without touching anything in the speakers, only through software, so an inexperienced user only can reach a volume not too high while at the same time seeing that the volume is in 100%. Any ideas? I went to...
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can't read
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can Not Read Found this in my Event Viewer on each start/restart. I don't have any Volumes that I have encrypted. Is this malware? I've run everything prior to noticing including Windows Offline Defender. Not sure if this is even the...
General Discussion
Volume too loud
I keep reading complaints about Win7 volume being too low. Oddly enough, I find my volume too high. Is there a way to tweak the volume settings for more subtley at lower levels? I hooked up a set of speakers to my computer that does NOT have hardware volume controls or a remote of any kind. ...
Too loud volume
I have a Corsair Vengeance 1500 headset, and when I use it it's always too loud. Even when I turn the volume down to 1, it's too loud at times. I have tried it on 3 different computers, and it happens on all of them. I have gone to the control panel and tried to turn down all sound options, but it...
Windows 7 x64 volume too loud problem
Hi, I did not find any solutions to my problem from the forum so I decided to create a new thread about this. Problem details: -Volume is too loud, I have to set master volume to 1-5%, anything over that is too loud. I have had no problems when using windows vista or windows XP. My setup:...
