please help with my realtek AC'97 !
  1. Posts : 4
    Windows Seven build 7057
    hello ! After installing Windows Seven on my Pc, I install XP realtek AC'97 drivers ! and I restarted my PC after reboot it worked fine ! but after shutting down the PC and switch it on the sound do not work !!
    so please help me to solve that probleme !
    ah !! I forget to show you the error message !
    the messege pecture is in the attachment file !
    sorry I speak frensh but I love your forum and hope so find the solution of this probleme !thnx a lot !
    Attached Thumbnails Attached Thumbnails please help with my realtek AC'97 !-capture.jpg
  2. Posts : 1,009
    Windows 7 RC 7100 32bit/64bit
    Hello Andromede31 and welcome to SevenForums!
    I suggest you uninstall the XP drivers and download the Vista version drivers for your AC'97 sound card, or use Windows Update and let it downoad the best driver available for you.
    Realtek
  3. Posts : 4
    Realtek
    thanks my brother Limneos!! I try it : I format all sound card drivers and I let WU search the best driver ! but win I reboot there is No sound but when I install the XP driver . it work but in the first reboot ! So please help me I love Windows Seven but one thing do not work is the sound!
    thnx !
  4. Posts : 1,009
    Then try downloading the drivers I posted above and see if that helps.
    These are Vista drivers, not XP. They should work better.
    Also please post your system specifications. particularly, your motherboard
  5. Posts : 4
    System Information
    Time of this report: 3/22/2009, 15:44:45
           Machine name: MOHAMED-PC
       Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7057) (7057.winmain.090305-2000)
               Language: French (Regional Setting: French)
    System Manufacturer: MICRO-STAR INC.
           System Model: MS-7065
                   BIOS: Version 1.00
              Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs), ~3.0GHz
                 Memory: 1024MB RAM
    Available OS Memory: 1024MB RAM
              Page File: 682MB used, 844MB available
            Windows Dir: C:\Windows
        DirectX Version: DirectX 11
    DX Setup Parameters: Not found
       User DPI Setting: Using System DPI
     System DPI Setting: 96 DPI (100 percent)
        DWM DPI Scaling: Disabled
         DxDiag Version: 6.01.7057.0000 32bit Unicode
    DxDiag Notes
          Display Tab 1: No problems found.
            Sound Tab 1: The file RTKVAC.SYS is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
            Sound Tab 2: The file RTKVAC.SYS is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
              Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D:    0/4 (retail)
    DirectDraw:  0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay:  0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow:  0/6 (retail)
    Display Devices
              Card name: Intel(R) 82865G Graphics Controller
           Manufacturer: Intel Corporation
              Chip type: Intel(R) 82865G Graphics Controller
               DAC type: Internal
             Device Key: Enum\PCI\VEN_8086&DEV_2572&SUBSYS_76501462&REV_02
         Display Memory: 92.5 MB
       Dedicated Memory: n/a
          Shared Memory: n/a
           Current Mode: 1280 x 1024 (32 bit) (60Hz)
           Monitor Name: Generic PnP Monitor
          Monitor Model:
             Monitor Id:
            Native Mode:
            Output Type:
            Driver Name: ialmrnt5
    Driver File Version: 6.14.0010.3943 (English)
         Driver Version: 6.14.10.3943
            DDI Version: 9
           Driver Model: unknown
      Driver Attributes: Final Retail
       Driver Date/Size: 11/2/2004 01:19:48, 37951 bytes
            WHQL Logo'd: Yes
        WHQL Date Stamp:
      Device Identifier: {D7B78E66-6632-11CF-B578-5A56A3C2CB35}
              Vendor ID: 0x8086
              Device ID: 0x2572
              SubSys ID: 0x76501462
            Revision ID: 0x0002
     Driver Strong Name: Unknown
         Rank Of Driver: Unknown
            Video Accel:
          Deinterlace Caps: n/a
           D3D9 Overlay: n/a
                DXVA-HD: n/a
           DDraw Status: Enabled
             D3D Status: Enabled
             AGP Status: Not Available
    Sound Devices
                Description: Speakers (Realtek AC'97 Audio)
     Default Sound Playback: Yes
     Default Voice Playback: Yes
                Hardware ID: PCI\VEN_8086&DEV_24D5&SUBSYS_76501462&REV_02
            Manufacturer ID: 1
                 Product ID: 100
                       Type: WDM
                Driver Name: RTKVAC.SYS
             Driver Version: 6.00.0001.6302 (English)
                WHQL Logo'd: No
              Date and Size: 11/26/2008 00:14:00, 4161504 bytes
                Other Files:
            Driver Provider: Realtek Semiconductor Corp.
             HW Accel Level: Basic
                  Cap Flags: 0xF1F
        Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
     Static/Strm HW 3D Bufs: 0, 0
                  HW Memory: 0
           Voice Management: No
     EAX(tm) 2.0 Listen/Src: No, No
       I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
                Description: Realtek Digital Output (Realtek AC'97 Audio)
     Default Sound Playback: No
     Default Voice Playback: No
            Manufacturer ID: 1
                 Product ID: 100
                       Type: WDM
                WHQL Logo'd: No
                Other Files:
                  Cap Flags: 0xF1F
                  HW Memory: 0
    Sound Capture Devices
                Description: Microphone (Realtek AC'97 Audio)
      Default Sound Capture: Yes
      Default Voice Capture: No
                  Cap Flags: 0x1
               Format Flags: 0xFFFFF
                Description: Line In (Realtek AC'97 Audio)
      Default Sound Capture: No
                  Cap Flags: 0x1
                Description: Phone Line (Realtek AC'97 Audio)
      Default Voice Capture: Yes
                  Cap Flags: 0x1
    DirectInput Devices
          Device Name: Mouse
             Attached: 1
        Controller ID: n/a
    Vendor/Product ID: n/a
            FF Driver: n/a
          Device Name: Keyboard
             Attached: 1
        Controller ID: n/a
            FF Driver: n/a
    Poll w/ Interrupt: No
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x8086, 0x24D2
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 3/6/2009 08:22:50, 250880 bytes
    | Driver: usbd.sys, 3/6/2009 08:22:18, 5888 bytes
    Gameport Devices
    PS/2 Devices
    + Standard PS/2 Keyboard
    | Matching Device ID: *pnp0303
    | Service: i8042prt
    | Driver: i8042prt.sys, 3/6/2009 07:33:21, 80896 bytes
    | Driver: kbdclass.sys, 3/6/2009 09:48:26, 42064 bytes
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    + PS/2 Compatible Mouse
    | Matching Device ID: *pnp0f13
    | Service: i8042prt
    | Driver: mouclass.sys, 3/6/2009 09:48:26, 41040 bytes
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    | Driver: termdd.sys, 3/6/2009 09:46:26, 51792 bytes
    | Driver: sermouse.sys, 3/6/2009 08:14:18, 19968 bytes
    Disk & DVD/CD-ROM Drives
          Drive: C:
     Free Space: 23.7 GB
    Total Space: 40.0 GB
    File System: NTFS
          Model: ST380011A ATA Device
          Drive: D:
     Free Space: 17.3 GB
    Total Space: 36.3 GB
    File System: NTFS
          Drive: E:
          Model: HL-DT-ST DVD-RAM GSA-H55N ATA Device
         Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7057.0000 (French), 3/6/2009 07:33:31, 108032 bytes
  6. Posts : 3,141
    Hello andromede31,
    Welcome to Seven Forums.
    I think what limneos meant was to go to your user CP and fill in your system specs. You can also click on the link in the lower left corner of one of your own posts and find a link. Fill in as much as you can. This will avoid you having to answer this question in each thread.
    Hope you enjoy your stay.
    Gary
  7. Posts : 4
    garysgold said:
    Hello andromede31,
    Gary
    thnx my brother ! I will !!
  8. Posts : 1
    Windows 7 Professional x86
    real rtkvac.sys file
    I've extracted the file from on old (pre-7) restore disk that came w/my computer....Hope this helps.....
    -=Mitch
    please help with my realtek AC'97 ! Attached Files
