Windows 7: Audio Driver Problem
24 Jan 2010   #11
merelda
Laptop: BENQ Joybook S53
I can't click onto it, unless I change my settings. So I guess it is already on default?
Still, nothing has happened after I changed it to default..
I'm sorry, this is probably highly annoying...
But I'm really appreciating your help :)
24 Jan 2010   #12
Orpheous
XP Pro/Vista Ultimate (64)/Windows 7 Ultimate Signature Edition(64)
No, it's not annoying, it's a challenge :)
Ok, we might see if MS can help out a little...
Click start orb type find and fix audio playback, hit enter and allow the troubleshooter to check your system.
Post back your results
24 Jan 2010   #13
merelda
Then the result makes this much more challenging, because "trouble shotting couldn't identify the problem", and I tried the "related troubleshooters online", but none of them are similar to my problem..
24 Jan 2010   #14
Orpheous
I'm going to request help from some more knowledgable SF team members here, I'll keep watching thouh in case there's anything else I can help with ok? Hopefully other members will be along soon to assist.
24 Jan 2010   #15
merelda
Thanks so much!!!!
Your help is greatly appreciated!!!
24 Jan 2010   #16
Orpheous
You're very welcome :)
24 Jan 2010   #17
theog
ME/XP/Vista/Win7
Can you take a screenshot of sound.This may help one of are memders.
https://www.sevenforums.com/tutorials...en-forums.html
24 Jan 2010   #18
merelda
Below are the screenshots:
Thanks!!
24 Jan 2010   #19
pebbly
are these the drivers you are using? BenQ Europe - Service & Support the only drivers i have found for your laptop relate to xp is an old laptop if so you may have to run in compatility mode
24 Jan 2010   #20
Orpheous
That 2nd image I believe is the key, can you repeat the steps in this tutorial: Driver selection for your Hardware devices. for each device with a yellow asterisk. Post back a screen snip for the hardware id's of each device
I've been trying to fix the audio driver on my custom build. The audio works fine for most programs, but for the Elgato Game Cap software I get no signal. When I go into the Device Manager under the sound, video and game controllers tab, 'VIA High Definition Audio' works fine but the 'High...
Problem installing AUDIO DRIVER
I'm running Windows 7 Ultimate 32bit. Motherboard > Gigabyte ga-m68mt-s2p When I manually install audio driver for Realtek alc-888b/889 from the dvd came with motherboard, still windows says 'No sound card was found. No driver installed....' I checked by running dxdiag. I can't get the...
Drivers
ok hi, i have just purchased a PC which im running as a server, with server 2008 (windows 7) I have managed to find the drivers for the NIC, now all that i need are the audio drivers. I have the multimedia controller in device manager, and it finds no drivers online. I have downloaded...
Drivers
Asus A8N-LA audio driver problem
Hey all...first post here. Seems like a great place, hope you guys can solve my problem. In searching for my missing driver, I came across this site, read the other threads, but nothing works. Here's the problem. I have an older pc that I just upgraded to Win 7 Ultimate 64bit. Everything...
Drivers
No Audio, Driver Problem
Hi, Recently I had a mishap with the Creative X-FI driver 7-30-2009 update, and I can no longer hear sound in Windows 7. As a result from this, most of my audio drivers/Creative X-Fi programs ended up deleted. At that point, I tried to uninstall my audio card from device manager and restart to get...
