Windows 7: Audio Driver Problem
24 Jan 2010   #21
merelda
Laptop: BENQ Joybook S53
Quote   Quote: Originally Posted by pebbly View Post
are these the drivers you are using? BenQ Europe - Service & Support the only drivers i have found for your laptop relate to xp is an old laptop if so you may have to run in compatility mode
No, I'm currently using Vinyl AC'97 Codec Combo Driver (WDM)
24 Jan 2010   #22
merelda
The first image is the one I posted before, which is taken before I updated the device
The second image is after I downloaded the zip file, then updated the device with the extracted files
The third image is the Hardware ids of Multimedia Audio Controller
The forth image is the Hardware ids of Mass Storage Device
The fifth image is the Hardware ids of Unknown Device
Thanks!!!
Audio Driver Problem-old.png Audio Driver Problem-after-installing-driver.png Audio Driver Problem-h-ids-audio-after-installing-driver.png Audio Driver Problem-mass-storage-controller.png Audio Driver Problem-unknown-device.png
24 Jan 2010   #23
theog
ME/XP/Vista/Win7
Quote   Quote: Originally Posted by merelda View Post
Why are not using BenQ drivers?
24 Jan 2010   #24
Orpheous
XP Pro/Vista Ultimate (64)/Windows 7 Ultimate Signature Edition(64)
Hi all,
I have a BENQ Joybook S53, and after I installed W7 last night, the audio stopped working. It says that I have "no audio devices installed"...
It also happened to me last time when I rebooted my XP, but after I downloaded the audio driver everything went well. However, this time, even after I downloaded and installed the audio driver, it still says the same thing!!
I even went back to XP and copied all the files regarding to "drivers" and pasted into WINDOWS (under C drive) and some others under System32... But it still isnt working for me...
I think my audio device is "Conexant AMC 2 Channel Audio" when I checked in XP..
Thank you for your help.
OP had issues with the original drivers
24 Jan 2010   #25
theog
ME/XP/Vista/Win7
Quote   Quote: Originally Posted by Orpheous View Post
Hi all,
Be alot of searching to get a better drivers.
24 Jan 2010   #26
merelda
Hi All :)
Thanks for helping me solving the problem!!!
I downloaded the driver from the below website:
BenQ Joybook S53 notebook Audio Driver
And then used the method Orpheous providedin the previous replies
i.e. go to device manage > sound, video and game controllers > right click properties > driver > update driver
although originally the "multimedia audio controller" is under 'other devices', but I think the principle is still the same.
Everything is functionally normally now.
p.s. I only copied the files extracted from the zip file and pasted in system32, that's why it didn't work originally!!! Oh and I have No Idea why I did that, it seemed logical to me that time..
Thank you so much for the help, really!!!
You guys are great!!!
24 Jan 2010   #27
pebbly
either method would have worked , but you got there in the end
24 Jan 2010   #28
Orpheous
Sorry for the mix up with the drivers, I was originally under the impression that you had tried installing the drivers in the traditional manner first!
Anyway, glad you managed to get it sorted out! Thanks for the input from theog and pebbly too!
24 Jan 2010   #29
pebbly
you,re welcome
24 Jan 2010   #30
theog
ME/XP/Vista/Win7
Good to here.
I've been trying to fix the audio driver on my custom build. The audio works fine for most programs, but for the Elgato Game Cap software I get no signal. When I go into the Device Manager under the sound, video and game controllers tab, 'VIA High Definition Audio' works fine but the 'High...
Problem installing AUDIO DRIVER
I'm running Windows 7 Ultimate 32bit. Motherboard > Gigabyte ga-m68mt-s2p When I manually install audio driver for Realtek alc-888b/889 from the dvd came with motherboard, still windows says 'No sound card was found. No driver installed....' I checked by running dxdiag. I can't get the...
Drivers
ok hi, i have just purchased a PC which im running as a server, with server 2008 (windows 7) I have managed to find the drivers for the NIC, now all that i need are the audio drivers. I have the multimedia controller in device manager, and it finds no drivers online. I have downloaded...
Drivers
Asus A8N-LA audio driver problem
Hey all...first post here. Seems like a great place, hope you guys can solve my problem. In searching for my missing driver, I came across this site, read the other threads, but nothing works. Here's the problem. I have an older pc that I just upgraded to Win 7 Ultimate 64bit. Everything...
Drivers
No Audio, Driver Problem
Hi, Recently I had a mishap with the Creative X-FI driver 7-30-2009 update, and I can no longer hear sound in Windows 7. As a result from this, most of my audio drivers/Creative X-Fi programs ended up deleted. At that point, I tried to uninstall my audio card from device manager and restart to get...
