Audio Driver Problem
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 21
    Laptop: BENQ Joybook S53
    I can't click onto it, unless I change my settings. So I guess it is already on default?
    Still, nothing has happened after I changed it to default..
    I'm sorry, this is probably highly annoying...
    But I'm really appreciating your help :)
  2. Posts : 551
    XP Pro/Vista Ultimate (64)/Windows 7 Ultimate Signature Edition(64)
       #12
    No, it's not annoying, it's a challenge :)
    Ok, we might see if MS can help out a little...
    Click start orb type find and fix audio playback, hit enter and allow the troubleshooter to check your system.
    Post back your results
  3. Posts : 21
    Then the result makes this much more challenging, because "trouble shotting couldn't identify the problem", and I tried the "related troubleshooters online", but none of them are similar to my problem..
  4. Posts : 551
       #14
    I'm going to request help from some more knowledgable SF team members here, I'll keep watching thouh in case there's anything else I can help with ok? Hopefully other members will be along soon to assist.
  5. Posts : 21
       #15
    Thanks so much!!!!
    Your help is greatly appreciated!!!
  6. Posts : 551
       #16
    You're very welcome :)
  7. Posts : 11,408
    ME/XP/Vista/Win7
       #17
    Can you take a screenshot of sound.This may help one of are memders.
    https://www.sevenforums.com/tutorials...en-forums.html
  8. Posts : 21
       #18
    Below are the screenshots:
    Thanks!!
    Attached Thumbnails Attached Thumbnails Audio Driver Problem-screenshot.png   Audio Driver Problem-old.png
  9. Posts : 6,243
       #19
    are these the drivers you are using? BenQ Europe - Service & Support the only drivers i have found for your laptop relate to xp is an old laptop if so you may have to run in compatility mode
  10. Posts : 551
       #20
    That 2nd image I believe is the key, can you repeat the steps in this tutorial: Driver selection for your Hardware devices. for each device with a yellow asterisk. Post back a screen snip for the hardware id's of each device
