Audio Driver Problem
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 21
    Laptop: BENQ Joybook S53
       #21
    pebbly said:
    are these the drivers you are using? BenQ Europe - Service & Support the only drivers i have found for your laptop relate to xp is an old laptop if so you may have to run in compatility mode
    No, I'm currently using Vinyl AC'97 Codec Combo Driver (WDM)
  2. Posts : 21
       #22
    The first image is the one I posted before, which is taken before I updated the device
    The second image is after I downloaded the zip file, then updated the device with the extracted files
    The third image is the Hardware ids of Multimedia Audio Controller
    The forth image is the Hardware ids of Mass Storage Device
    The fifth image is the Hardware ids of Unknown Device
    Thanks!!!
    Attached Thumbnails Attached Thumbnails Audio Driver Problem-old.png   Audio Driver Problem-after-installing-driver.png   Audio Driver Problem-h-ids-audio-after-installing-driver.png   Audio Driver Problem-mass-storage-controller.png   Audio Driver Problem-unknown-device.png
  3. Posts : 11,408
    ME/XP/Vista/Win7
       #23
    Why are not using BenQ drivers?
  4. Posts : 551
    XP Pro/Vista Ultimate (64)/Windows 7 Ultimate Signature Edition(64)
       #24
    merelda said:
    Hi all,
    I have a BENQ Joybook S53, and after I installed W7 last night, the audio stopped working. It says that I have "no audio devices installed"...
    It also happened to me last time when I rebooted my XP, but after I downloaded the audio driver everything went well. However, this time, even after I downloaded and installed the audio driver, it still says the same thing!!
    I even went back to XP and copied all the files regarding to "drivers" and pasted into WINDOWS (under C drive) and some others under System32... But it still isnt working for me...
    I think my audio device is "Conexant AMC 2 Channel Audio" when I checked in XP..
    Thank you for your help.
    OP had issues with the original drivers
  5. Posts : 11,408
    ME/XP/Vista/Win7
       #25
    Orpheous said:
    merelda said:
    Hi all,
    Be alot of searching to get a better drivers.
  6. Posts : 21
       #26
    Hi All :)
    Thanks for helping me solving the problem!!!
    I downloaded the driver from the below website:
    BenQ Joybook S53 notebook Audio Driver
    And then used the method Orpheous providedin the previous replies
    i.e. go to device manage > sound, video and game controllers > right click properties > driver > update driver
    although originally the "multimedia audio controller" is under 'other devices', but I think the principle is still the same.
    Everything is functionally normally now.
    p.s. I only copied the files extracted from the zip file and pasted in system32, that's why it didn't work originally!!! Oh and I have No Idea why I did that, it seemed logical to me that time..
    Thank you so much for the help, really!!!
    You guys are great!!!
  7. Posts : 6,243
       #27
    either method would have worked , but you got there in the end
  8. Posts : 551
       #28
    Sorry for the mix up with the drivers, I was originally under the impression that you had tried installing the drivers in the traditional manner first!
    Anyway, glad you managed to get it sorted out! Thanks for the input from theog and pebbly too!
  9. Posts : 6,243
       #29
    you,re welcome
  10. Posts : 11,408
    ME/XP/Vista/Win7
       #30
    Good to here.
