Sound Blaster X-Fi Xtreme Audio 70SB104000001
  1. Posts : 1
    Hi
    Im looking at Sound Blaster X-Fi Xtreme Audio 70SB104000001
    i was wandering if anyone had any advice on this card. i can't see it on the seven compatiblity site but Creative has windows seven drivers to download.
    I was looking at the PCIe x 1 version as i have either a PCIe or PCI slot availble.
  2. Posts : 5
    Windows 7 Professional 32-Bit
    Hey there Click your Windows Orb and In search bar Type Device Manager hit enter then find where your card is listed if it is listed then right click it then update drivers if it finds it and installs it then you should be done if not then Power down PC Pull the card out then Look to see if your card slot is dirty or the pins if they are both clean then it should be in your device manager.
