Slightly confused about Motherboard sound options
  1. Posts : 983
    10 x64 | 7 x64
    Ok this post is probably going to make me 'sound' like a wing-nut but here it goes.
    First, always been happy with plain old stereo speakers before, no frills decent sound. Now, with 7 and media center I'm looking to go 2.1 maybe 4/5.1 for movies and jazz up a few games.
    Good plan? So I check the manual and this is the jazz I see:
    Center/Subwoofer Speaker Out Jack (Orange)
    Use this audio jack to connect center/subwoofer speakers in a 5.1/7.1-channel audio configuration.
    Rear Speaker Out Jack (Black)
    Use this audio jack to connect rear speakers in a 4/5.1/7.1-channel audio configuration.
    Side Speaker Out Jack (Gray)
    Use this audio jack to connect side speakers in a 7.1-channel audio configuration.
    Line Out Jack (Green)
    The default line out jack. Use this audio jack for a headphone or 2-channel speaker. This jack can be used to connect front speakers in a 4/5.1/7.1-channel audio configuration.
    I don't want to buy the wrong speakers/set-up. So for a plain 2.1 I would use just the (Green) jack and I'm told this will do 2.1 but what gives with the (Orange) jack.
    I guess 4.1 is out of the question unless I do two sets of stereo speakers and a seprate sub?
    That leaves 5.1 I guess. I don't understand what the deal/use of the (orange) jack is all about if 2.1 4/5.1 speaker sets bleed off the (green) for .. is it to early to start drinking?
  2. Posts : 11,840
    64-bit Windows 8.1 Pro
  3. Posts : 2,036
    Windows 7 Professional x64
    Tews said:
    LOL Wow! I wish I could follow that post. I sincerely hope someone can help you.
  4. Posts : 6,879
    Win 7 Ultimate x64
    In most cases a 2.1 set (two fronts and a sub) connect to the green on the sound card, with that cable going to the sub and the fronts running off of it. Same goes for most 5.1 sets; the fronts, rears and center/sub all connect to the appropriate jacks on the sound card (with the three cables usually in a bundle), something like this,
    http://images17.newegg.com/is/image/...36-121-006-S08
  5. Posts : 11,840
    I figured since i couldnt follow the post, might as well have a shot or two....or three....
  6. Posts : 2,528
    Windows 7 x64 Ultimate
    Well since the center channel and subwoofer frequency ranges do not cross at all (Each set of amps/speakers would filter out the others freq range) It's apparently being used for both. So if you have a center channel AND subwoofer output you need to put a Y cable into the orange jack and run one to the center and the other to sub.
    It LOOKS like the way the sound is setup you don;t get any sub if you don;t have a center channel but sometimes the manuals can be a bit terse and not fully explaing things. Give 2.1 a try, it'll either work or it wont. But given that 4 ch has no sub listed there may not actually be any 2.1 either. I'd try it anyway, you never know.
  7. Posts : 6,879
    Win 7 Ultimate x64
    You sure about any of that? This is from the manual for the back of the speakers I linked to,
    and yes the sub and center both go off the same cable. And a 2.1 set will be similar in that there is only one cable connected between the speakers and the sound card, with the fronts connecting to the sub.
  8. Posts : 2,528
    Well weather there is a single wire going to your center and sub for your speaker system or weather you need a Y cable because the amp inputs are seperate is a matter of your exact speaker setup.
    I don't use PC speakers myself, I use a pair of autio monitoers and a seperate sub so in that case you need to run the sub off a seperate wire from center (if you wanted to use center). If you have a PC speaker set that is relatively current to your MB and all the wire colors match then you can just match color for color and go :)
  9. Posts : 983
    10 x64 | 7 x64
    Alrighty well I think with this new ammunition I can tackle a problem if one pops up. Thanks guys, I'll look at a decent 2.1 system and if that works out - upgrade.
