"No Audio Output Device Is Installed"
  1. Posts : 8
    1122
    This has probably been posted here before, but I could not find any threads on this issue. I re installed Windows 7, and once I finished, I logged on, and tried to watch a video online, and realized there was no audio. I looked at the speaker to see if it was turned on, and there was of course a red x on it, and the message "No Audio Output Device Is Installed" once I dragged the mouse over it.
    Any idea on how I can fix this?
  2. Posts : 4,772
    Hello Willbug, Welcome to SF,
    I guess the Audio Drivers didn't got installed.
    Go To > Start > Device Manager > Look for Yellow Marks if your finding it then
    Right Click Update Drivers
    Also Control Panel> All Control Panel Items> Troubleshooting > Hardware and Sound See what does it finds
    Captain
  3. Posts : 8
    1122
    So I opened the Device Manager, and saw that my Multimedia Audio Controller had a yellow mark next to it. I right clicked and clicked "update driver software" and this message came up.
    " Windows could not find Driver Software for your device."
    Anything else I should attempt?
  4. Posts : 4,772
    Do you know what sound card are you using ?? Onboard or External Card ? If its Onboard and if your not sure post us Motherboard Model will try to find them.
    Good Luck,
    Captain
  5. Posts : 8
    1122
    I'm not sure as to what Sound Card I'm running. How can I find out?
    EDIT: Figured it out, it's an onboard soundcard
  6. Posts : 11,408
    ME/XP/Vista/Win7
    Can you post specs.
  7. Posts : 4,772
    Post us the MSINFO32 file
    MSINFO32
    Please go to Start and type in "msinfo32.exe" (without the quotes) and press Enter
    Save the report as an .nfo file, then zip up the .nfo file and upload/attach the .zip file with your next post.
    If you're having difficulties with the format, please open an elevated (Run as administrator) Command Prompt and type "msinfo32 /nfo C:\Users\Public\Desktop\TEST.NFO\" (without the quotes) and press Enter. Then navigate to the C:\Users\Public\Desktop directory to retrieve the TEST.NFO file. If you have difficulties with making this work, please post back.
    Captain
  8. Posts : 8
    1122
    Sorry it took so long: Download NFO.zip from Sendspace.com - send big files the easy way
    That's what you wanted me to do right?
  9. Posts : 4,772
    Got it ..
    Sound Card: SoundMAX Integrated Digital Audio
    PND Device: PCI\VEN_8086&DEV_27DE&SUBSYS_01AD1028&REV_01\3&172E68DD&0&F2
    Multimedia Audio Controller    PCI\VEN_8086&DEV_27DE&SUBSYS_01AD1028&REV_01\3&172E68DD&0&F2    The drivers for this device are not installed.
    We got lot of thread that has the way to obtain the drivers Windows 7 Forums the biggest Windows 7 discussion forum, friendly help and many Windows 7 tutorials that will help you get the most out of Microsofts new Windows 7 Operating System. - Search Results for SoundMax audio drivers
    Captain
