no sound
  1. Posts : 18
    Windows Seven
    "wnt_6.1p_mce"
    hey i just clean installed win7, but my problem is i got no sound, i found my Motherboard driver but its only conpatible for windows vista and older version....no W7
    but, i downloaded windows vista audio and got a message
    "AsusSetup, does not support this operation system: WNT_5.1P_MCE"
    any fix?
  2. Posts : 6,879
    Win 7 Ultimate x64
    What motherboard? This,
    would help a lot.
  3. Posts : 18
    Windows Seven
    would help a lot.
    finished those form. but i downloaded the old version driver, it installed but at the last moment it says "realtek error code 0x00000103" http://i585.photobucket.com/albums/s...e123/audio.png
    motherboard: ASUS m3a
  4. Posts : 6,879
    Win 7 Ultimate x64
    Try the latest Realtek HD driver instead,
    Latest Realtek HD Audio Driver Version
    for that no need of for the CD or what is available from Asus.
  5. Posts : 18
    Windows Seven
    just downloaded it, nothing happends still...when i listen to music the audio bar moves up and down, but no audio comming out of speaker.
  6. Posts : 6,879
    Win 7 Ultimate x64
    Speakers set as default in both the Windows and Realtek audio controls? Nothing set as digital/spdif out?
    Also stupid question time, speakers connected to the correct jack in the back?
  7. Posts : 18
    Windows Seven
    nvm, i fixed my problem:
    how i fixed it:
    downlaoded lastest driver
    - opened realtek manager
    - clicked folder in top right and disabled
    - done
  8. Posts : 173
    Hello Colgate-
    I am glad you resolved this issue. For more resources regarding hardware and driver issues go here: Help with Windows 7 compatibility problems - Help & How-to - Microsoft Windows.
    Cheers,
    Tara
    Windows Outreach Team
  9. Posts : 1
    It doest have the driver, only xp 64bit driver. If I'm going to use the xp 64bit driver using the xp mode, will this work?
  10. Posts : 1,797
    Windows 7 Ulti. x64
    smile25 Hello and welcome to SevenForums
    The compatibility mode has worked for me in some situations. Good luck to you.
    Compatibility Mode
