reboot loop after instaling sound card
  1. Posts : 8
    i had instaled windows 7 ulimate on my PC which had pentium4 on it
    after i instaled SoundBlasterAudigy from windows update my PC reboot by itself
    even after i turn off "automatically restart" option, my pc still restarted by itself
    please help me o resolve this problem
  2. Posts : 150
    Windows 7 Ultimate 64-Bit
    Try starting in safemode and uninstalling drivers.
    Tap F8 on start up and select "Safemode" and remove drivers and restart.
    See if that works.
  3. Posts : 8
    i was try it
    but it didn't work
  4. Posts : 150
    Did it load into safemode?
    Whats the model of the soundcard?
  5. Posts : 11,840
    64-bit Windows 8.1 Pro
    Insert your windows7 DVD and do a repair install ... this should stop the rebooting... then reinstall your drivers... I would recommend making a system image in case you have problems in the future...
    Backup Complete Computer - Create an Image Backup
  6. Posts : 150
    May also be worth letting windows update detect the driver for now to see if installs correctly.
  7. Posts : 8
    the reboot loop was stop
    now, how i can instal my soundcard correctly??
  8. Posts : 150
    Try running windows update and looking for "optional Updates"
  9. Posts : 11,840
    go to your device manager and click on sound & video tab...update driver ... that should install the correct driver...otherwise, download the driver manually, boot into safe mode and install it ... let us know how it turns out...
  10. Posts : 8
    alright,i made a mistake......
    well,the restart was stoped at least 2 hours after i uninstaled the soundCard software.....
    the worst is reboot prosses take 30minute......
    at first i thought its because i didn't update the Se7en, even i was update it,he restart loop doesn't stop
    now, i don't know what should i do to fix it
