PCI simple communication + Front jack Problems
  1. Posts : 2
    hello, before i installed my windows 7, i was running on windows xp(SP3) but yesterday I had installed windows 7 and all i got to say is it's Fantastic compared to windows xp. except I had kind of ran into couple problems, such as after i had used "Driver Genius pro edition" + "unknown Device" and gotten all of the proper drivers for my new OS, every thing works fine except for PCI simple communication controller not beening able to install, I have a feeling that this is also the reason why my 3.5mm front mic jack doesn't work. My mic use to work with Windows xp, now... not so much
    Specs:
    MoBo: Intel ~ DP965LT
    Intel Dual Core2 CPU (1.86 GHz x 2 so 3.6GHz)
    Ram 4GB DDR 2
    500gb of Hard Drive
    Video card ~ Radeon x1600 (going to be upgraded soon )
    Microphone : 3.5mm Speaker/mic Jacks. Front and Back
    I have been tried all kinds of driver's and stuff.. they are either incompadiable with OS windows 7 or MoBo. The I can't seem to manage to fix this problem, so any help is very appreciated
  2. Posts : 2
    FIX for PCI Simple commuinication driver
    even though i asked for some help on the forums, i still kept looking and actually found a VERY helpful post that basically fixed my problem.
    For all those with a 965 series Intel chipset, I was able to get the driver working. [COLOR=#0072BC ! important][COLOR=#0072BC ! important]Intel[/COLOR][/COLOR] doesn't list the Management Engine Driver under the drivers-for-965 list, but they do list it under Desktop Boards -> Q963 Express Chipset Boards.
    This driver is also compatible with the 965 chipset. Here is the link:
    Intel® ME: Management Engine Driver for Intel 963/965 Chipset-Based Desktop Boards
    Once you download it, you'll have to run in win [COLOR=#0072BC ! important][COLOR=#0072BC ! important]WinXP[/COLOR][/COLOR] compatibility mode (right-click the file once you download it, go to the compatibility tab, and select WinXP mode.)
    Worked for me, good luck.
    by "eDeloa"
    also for those who are having problems with PCI simple communication drivers and have intel MoBo :
    Intel® Desktop Board DG965MQ
    Intel® Desktop Board DG965MS
    Intel® Desktop Board DG965OT
    Intel® Desktop Board DG965PZ
    Intel® Desktop Board DG965RY
    Intel® Desktop Board DG965SS
    Intel® Desktop Board DG965WH
    Intel® Desktop Board DP965LT
    Intel® Desktop Board DQ963FX
    Intel® Desktop Board DQ963GS
    Intel® Desktop Board DQ965CO
    Intel® Desktop Board DQ965GF
    Intel® Desktop Board DQ965WC
    i suggest u download that link i provided, its what you need :]
  3. Posts : 6,243
    thank you for that helpful post
