Windows 7: W7 64 bit Home Ed. Audio Priority Issue
19 Feb 2010   #1
clarefourseven
Windows 7 64 bit Home Edition
Whatever audio I have running initially, such as wmv, vlc, youtube, the sound will lose 50% of it's normal volume when I run a game.
For example, I'm watching Youtube videos then I launch my windowed mode 'Team Fortress 2' or 'Counter Strike' game, once I join a game/server, I'll have the game volume at a normal 100% volume where as the youtube video will automatically drop down to 50% of normal volume.
I'm also on an non genuine version of windows 7 64 bit home edition. I purchased the $30 copy from microsoft that was solely for college students. the site did not say anything about it being an upgrade disc only .. But I don't think that's the cause of my audio priority issue
Any thoughts?
20 Feb 2010   #2
Aphelion
Windows 7 Home Premium
When you right click on the Microsoft Speaker icon in the task bar and select playback devices do you see a communications tab? Is the volume reduction selected, not sure if it would be triggered by a game?
There is another MS setting under the enhancements tap (Speakers/Properties) that is a type of compression/limiting called "Loudness Equalization", might check and see if that's active.
Ap
21 Feb 2010   #3
clarefourseven
cool, the first one solved my issue. I feel like a lazy bum now :>
10 Mar 2011   #4
Clueless1
Fixed.
Unable to Click Certain Objects Weird Window Priority Issue
Hey Windows 7 Forums, Having a huge issue I am having a hard time conveying with words, so I have made a video I uploaded to YouTube here: https://www.youtube.com/watch?v=x1-33S8KnLs Basically, I am having an issue where right from the moment I log-on, some programs are having issues where I...
General Discussion
ManyCam Issue (Audio Issue)
Hi, I am trying to play music via the Audio tab within ManyCam through a broadcasting website, but when I set it up to play and then I start broadcasting, the music sounds all distorted, staticy and double playing. What am I doing wrong? Do I have to change something in my sound settings?
audio issue with windows 7 home edition/realtek
hopefully somebody can assist me here as ive spent 3 hours getting nowhere with it aha basically i had my computer packed away for 6 months beforehand it was working perfectly i could plug is any headset/speaker set and it worked fine today i got the computer out and set it up using same...
Home audio systems :)
I consider my audio system pretty amazing and was just thinking what are your systems like out there?? My setup : Sony dx50 600 watt head-unit x5 satellite speakers around my room ( Panasonic 80watts 4 ohms ) x2 Sharp acoustic sound Left and right front speakers ( 50 watts 4 ohms )
Chillout Room
Audio Problem in Home Premium x64
This seemed to be a very frustrating issue for me. When I turned on my computer, everything is working fine. But oftentimes, after a couple of hours (4-5 or more) of turning on the computer, a sudden X mark will appear on the Audio Icon in the taskbar at the buttom right. When you hover the...
