Windows 7: Audio-out to Audio-in cable
21 Feb 2010   #1
cclloyd9785
Windows 7 Home Premium x64, Mac OS X 10.6.2 x64
Anyone know of a at least 4' audio out to audio in cable. Pretty much a double sided headphone jack.
21 Feb 2010   #2
stormy13
Microsoft MVP
Win 7 Ultimate x64
Might want to try and find something local as shipping will be more than the cable is worth but,
HDMI Cable, Home Theater Accessories, HDMI Products, Cables, Adapters, Video/Audio Switch, Networking, USB, Firewire, Printer Toner, and more!
22 Feb 2010   #3
Aphelion
Quote   Quote: Originally Posted by cclloyd9785 View Post
Oh, a "What You Hear" cable!
They used to ship those with some audio cards, the hard part is finding a short one.
Try a search on 1/8" male to male stereo cable.
Amazon.com: 3.5mm Stereo Male To Male Cable 3 ft.: Electronics
A 3ft one on Amazon. Try eBay.
Ap
22 Feb 2010   #4
cclloyd9785
Yea thanx both of you. I searched 3.5mm cable, and found one at the local radioshack.
22 Feb 2010   #5
fireberd
You should use a shielded "audio" cable and NOT a "speaker" cable that is not shielded. 1/8" (3.5mm) stereo plugs on each end.
Difference between Audio Cable and Aux Cable
Hello I have a quick question! what is the difference between Audio Cable and Aux Cable? Is there any difference in sound quality or in Left Right Channel Sound? I'm asking because I recently bought Edifier C2 2.1ch Sound System for my PC that has an External Amplifier that has Aux Input as well....
hdmi cable to LG tv no audio
hi, i have my pc connected to a LG flatron 22" tv by hdmi cable the picture is fine but the audio does not play through the tv, a jack cable from the pc to the tv does not work either, if i use the jack plug into separate speakers it will play the audio through the speakers. i have checked in...
HDMI Cable/Good video/No audio
I see on the forum that this has been a problem for a long time but I don't see where anyone has figured it out yet. If I missed something please enlighten me. I built up a computer to use with my HDTV. A Gigabyte GA-E350N-USB3 MB loaded with W7x64. Audio and sound worked fine when it was...
Cable for digital audio out for SB Audigy 2 card
I have a very old but very functional computer that I'd like to connect to my surround sound PC speakers. I currently have the computer connected to the speakers via the analog green, yellow and black cables, but my card states that it can support digital audio out, but I'm not sure what kind of...
Don't know were to put audio cable in hd sound input
I got a Compaq Persario V3000 and I have a Digital Audio (S/PDIF) built in my laptop and I don't know were to put my sound cable. There are two Speakers which I know were to put them but for Digital Audio (S/PDIF) it say it is located in the Rear Panel jack Please help me.I know it...
