Windows 7: Not getting any sound to my 5.1 from Digi Optical cable
25 Feb 2010   #11
JohnnyScience
Windows 7 64 & Ubuntu 64
I dont get it, I have my computer speaker working through my sound card via 3.5mm jack, but yet the optical that is on the same sound card isnt working even when I set s/pfid as default in the sound settings? (The meter still moves, but no sound at all?)
25 Feb 2010   #12
JohnnyScience
I've posted on the Asus forums in helps to disable the onboard sound, so hopefully we can get to the bottom of this very soon. (I've got a music project due monday)
26 Feb 2010   #13
JohnnyScience
bump
26 Feb 2010   #14
seekermeister
Go into the Device Manager and disable the onboard sound.
26 Feb 2010   #15
stormy13
Microsoft MVP
Win 7 Ultimate x64
Have you gone though any of the FAQ's on the TB knowledge base,
S/PDIF Out - How to use - Turtle Beach :: Knowledgebase
Might be worth checking all the various ones there dealing with SPDIF and digital out, just to make sure you have all the settings correct.
28 Feb 2010   #16
JohnnyScience
Ok I did all of that & tried both 44.1 & 48khz & still nothing. The meter bar inside of the sound device is moving, but I dont even get anything to my sub..
I tried to disable everything other thand the s/pdif & it still didnt work and now the other options are gone for me to enable them again - how do I do re-enable them?
Any other ideas?
01 Mar 2010   #17
JohnnyScience
still stuck...
02 Mar 2010   #18
JohnnyScience
any help on this? I have another sound project due tomorrow & if I dont get this working I cant do the project.
thanks
04 Mar 2010   #19
jlamphere
Windows 7 64Bit
are you connecting this sound card to an (receiver/amp) or 5.1 speakers? what kind?
you might want to check and see how many s/pdif ports you have on the back of each.
I know i have 3 on my computer, 1 in > 2 out ..
and on my receiver i have 2 1 in > 1 out
though i use an x-fi card..
04 Mar 2010   #20
JohnnyScience
Quote   Quote: Originally Posted by jlamphere View Post
yeah there is only 1 optical port on my card & my sony 5.1 - the surround plugs right into the dvd/amp (its a box kit 5.1, but its still nice)
I used to have it hooked up fine on XP Pro, but I dont think I've ever tried setting it up on 7 until now.
But I'm still stuck?
S/PDIF Optical out - No sound from receiver (onboard and sound card)
I've got an Asus Crosshair V Formula motherboard that I couldn't get any sound on my Onkyo HT-R550 receiver via the onboard optical output (Win 7 Ultimate 64 bit OS) I was planning on getting a nicer sound card anyway, so I bought the Asus Xonar Essence ST. Installed that sound card but alas, I...
No sound through SPDIF out (red) Optical.
Hi, I have a Gigabyte GA-Z68X-UD3h-B3 Motherboard, which has a SPDIF out port on it. I followed the instructions by going into the Realtek Audio manager and setting it to "Digital Output (Optical) " and when I test it, no sound comes out, it is hooked up to a Vizio HD Tv, Im using a Nvidia 8800 GT...
Optical cable recognised as HDMI
Hello everybody, I have a Windows 7 enterprise 64 bit pc and an Onkyo receiver. I used to have them linked with an aux cable for music. But since I had enough of the bad sound quality I bought an optical cable and connected it. Now I have the problem that my subwoofer gives a lot of less sound...
Hardware & Devices
No sound through the HDMI cable
I have a TV with HDMI and when possessed Vista both the sound and image were transmitted by cable, put the 7 and only the image is transmitted on television, the sound driver is installed and supports HDMI transmission is the same as used in Vista. How can you fix the problem? I did not know...
Don't know were to put audio cable in hd sound input
I got a Compaq Persario V3000 and I have a Digital Audio (S/PDIF) built in my laptop and I don't know were to put my sound cable. There are two Speakers which I know were to put them but for Digital Audio (S/PDIF) it say it is located in the Rear Panel jack Please help me.I know it...
