Windows 7: Not getting any sound to my 5.1 from Digi Optical cable
04 Mar 2010   #21
Dwarf
Windows 8.1 Pro RTM x64
If you look at the optical port without anything plugged in, is there any visual indication of port activity? Do you see a red light?
05 Mar 2010   #22
JohnnyScience
Windows 7 64 & Ubuntu 64
Quote   Quote: Originally Posted by Dwarf View Post
No there isnt any light, but I thin k thats normal for my card?
I'm still totally stuck on this one... I'm still working on trying to disable the mobo sound without disabling the HD sound like I had the issue with before.
I dont understand if the 3.5mm jack works out of the card, why isnt sound being produced to the s/pdif thats on the same card? (and is now on & activated in the turtle beach riviera control panel)
05 Mar 2010   #23
stormy13
Microsoft MVP
Win 7 Ultimate x64
Don't why you're doing that, they are one and the same; all of those things listed as "HD Audio Device" back in those screen shots of yours are the onboard audio, just without the proper drivers installed. Disable the onboard audio and don't worry about the missing "HD Audio Device" as it can't and won't make any difference to your sound card.
Quote:
No there isnt any light, but I think thats normal for my card?
No it isn't. your card only has an optical digital out pot,
Turtle Beach Riviera - In Detail
and if there isn't a light showing in it (usually red), then it either isn't enabled or is faulty.
09 Mar 2010   #24
JohnnyScience
Quote   Quote: Originally Posted by stormy13 View Post
Ok I went back into the onboard sound & disabled what was listed as HD whatever.
I came back to windows & played a cd in the actual dvd 5.1 itself & gets sound perfect, but when I switch it over to SAT, nothing coming out via the s/pdif but it is coming out of my little computer 3.5mm speaker.
Heres an updated screen shot, I have the s/pdif set up to be on...
09 Mar 2010   #25
JohnnyScience
I also just downloaded the newest win7 64 driver here:
Turtle Beach :: Knowledgebase / Download
When I tried to install it, Modify was what defaulted, but there was nothing to actually select as you can see in the picture:
So instead I did Repair, it ran through a process & required me to restart my computer.
I still have no sound through the s/pdif
I know the card works fine as I used to have it set up this way before I moved with XP Pro.
Not getting any sound to my 5.1 from Digi Optical cable-untitled8.png Not getting any sound to my 5.1 from Digi Optical cable-untitled9.png
09 Mar 2010   #26
stormy13
Microsoft MVP
Win 7 Ultimate x64
Quote   Quote: Originally Posted by JohnnyScience View Post
One thing missing from that screen shot, you didn't set the SPDIF as the default device in the Windows settings.
09 Mar 2010   #27
JohnnyScience
When I disabled the HD onboard sound from bios it took away the s/pdif setting for me to enable?
And when I switch it to that digital output, it just comes back out of the 3.5mm speaker, but in like a different tone or something its weird, but still not the 5.1?
09 Mar 2010   #28
stormy13
Microsoft MVP
Win 7 Ultimate x64
That optical output setting is the same as SPDIF, SPDIF and optical are both digital.
Try this, unplug both the speakers and the USB headphones and then try using just the optical connection. If it still doesn't work then I have a feeling it will be down to the TB drivers that are causing the problem.
Also,
Quote:
No Sound - Optical Connection:
Make sure that you set the system for 2 speakers, select the S/PDIF
and the Optical Connection should work.
No Sound - Turtle Beach :: Knowledgebase
09 Mar 2010   #29
JohnnyScience
Also,
Ok I put it on the Digital Output, unplugged the 3.5mm cable & even checked the master sound in the mixer of Turtle beach control panel & still nothing?
Perhaps I'll have to contact TB?
09 Mar 2010   #30
stormy13
Microsoft MVP
Win 7 Ultimate x64
You set it to stereo/2.0/2.1?
S/PDIF Optical out - No sound from receiver (onboard and sound card)
I've got an Asus Crosshair V Formula motherboard that I couldn't get any sound on my Onkyo HT-R550 receiver via the onboard optical output (Win 7 Ultimate 64 bit OS) I was planning on getting a nicer sound card anyway, so I bought the Asus Xonar Essence ST. Installed that sound card but alas, I...
No sound through SPDIF out (red) Optical.
Hi, I have a Gigabyte GA-Z68X-UD3h-B3 Motherboard, which has a SPDIF out port on it. I followed the instructions by going into the Realtek Audio manager and setting it to "Digital Output (Optical) " and when I test it, no sound comes out, it is hooked up to a Vizio HD Tv, Im using a Nvidia 8800 GT...
Optical cable recognised as HDMI
Hello everybody, I have a Windows 7 enterprise 64 bit pc and an Onkyo receiver. I used to have them linked with an aux cable for music. But since I had enough of the bad sound quality I bought an optical cable and connected it. Now I have the problem that my subwoofer gives a lot of less sound...
Hardware & Devices
No sound through the HDMI cable
I have a TV with HDMI and when possessed Vista both the sound and image were transmitted by cable, put the 7 and only the image is transmitted on television, the sound driver is installed and supports HDMI transmission is the same as used in Vista. How can you fix the problem? I did not know...
Don't know were to put audio cable in hd sound input
I got a Compaq Persario V3000 and I have a Digital Audio (S/PDIF) built in my laptop and I don't know were to put my sound cable. There are two Speakers which I know were to put them but for Digital Audio (S/PDIF) it say it is located in the Rear Panel jack Please help me.I know it...
