Taskbar volume icon problem
Page 2 of 2 FirstFirst 12
  1. Posts : 23
    Windows 7 Home 64bit
    Well... i opened my computer this morning and all the system icons where off and greyed out like usual.
  2. Posts : 23
       #12
    I think i might have to reformat, that should probably fix my problem, right?
  3. Posts : 72,062
    I would try a repair install first to see if you can avoid a full clean install. This way you will not lose anything.
  4. Posts : 1
    I have found the answer.
    Some How the icons are hiding underneath eachother.
    so grab the top of the taskbar pull it up and then move it back down and the icons will be organized in the right order again.
    no fortmatting.
    no Restarting.
    Really Simple..
