Sound is soft
  1. Posts : 11
    Windows 7 Home
    Sound is soft
    I just tried out the media center but I noticed that when playing files the sound is soft. The media center splash screen is loud when I open the program but I have to turn the volume way up to have it play normal. When I use Media Portal which is almost the same as Media Center the volume is fine. I even tried uninstalling Media Portal just in case the codecs conflict or something. Is there a setting I have to change? I configured the audio in media center for 7.1 speakers.
    Sorry I posted this in the wrong section. Mods can you move it to the Media Center section. Thanks.
  2. Posts : 1,939
    Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
    The + and - sign buttons also adjust the volume in WMC... have you tried them?
  3. Posts : 11
    Windows 7 Home
    I think so. I will have to try it again when I get home. All I remember was 50 was the max.
