Unexpected sound at startup
  1. Posts : 175
    Windows 7 Ultimate
    Windows 7 Ultimate 64-bit
    Hello:
    In Control Panel, > Sound > Sounds tab, I have Sound Scheme = No Sounds and the checkbox "Play Windows Startup Sound" is unchecked. Still, whenI start Windows, at the end, there is a sound (I have not found it among the Win /wav files).
    Is there any way it can be a system sound, or would it be an application (not UltraMon, my multimonitor/wallpaper app?
    Thanks for any suggestion.
    Regards,
    Hans L
  2. Posts : 143
    Windows 7 Home Premium 64 bit
    You've determined that the sound is NOT the standard Win startup sound, nor any of the standard sounds found in the Windows sound folder; unfortunately, that still leaves a lot of processes/programs that might generate it.
    If immensely curious, you can get Sysinternals autoruns, and disable each of the startup/logon processes one by one (trial and error?), and perhaps find it by process of elimination..?
  3. Posts : 175
    Windows 7 Ultimate
    I am immensely curious I will try Autoruns. Thanks.
    Hans L
