Windows 7: Low & Loud Problem Win7
27 Feb 2010   #1
hitman000
When i set my rig up i had a coolermaster aquagate kit. Sadly it leaked down my motherboard onto my video card. Luckly it never harmed it as im using the same parts now. About 2 months later my onboard sound just went off. Tried reinstalling drivers etc to no avail so i bought my sb audigy se soundcard. The other night i installed win7 to a spare partition to play with. It had installed my onboard drivers automatic so i thought i'll try plugging my speakers in and it worked. But i had no control panel for equalizer etc so i got my driver from realtek's site and reinstalled & now its went off again. Also when i play music i like to sometimes adjust the play speed a lil bit. XP works fine but on Vista & Win7 it seems to make the music go low & loud. Its kinda hard to describe. Can anyone shed some light on this?. :)
I have my rig connected to a Technics SCDV-290 and it sounds really crappy lol. This is the only thing thats stopping me using 7 as a primary OS.
08 Mar 2010   #2
hitman000
Re-Edited my post incase people didnt understand what i ment.
Cheers.
08 Mar 2010   #3
Aphelion
Windows 7 Home Premium
Quote   Quote: Originally Posted by hitman000 View Post
Cheers.
For the Loud & Low problem, check this thread:
automatic volume variations
Look for my post, I think it's the third one down, it will also give some insight as to where the other effects are.
Ap
08 Mar 2010   #4
hitman000
Thanks for the reply Ap, Im logged onto win7 now and it doesnt have that in the properties (loudness equalization) for my sb audigy, I cant get my onboard to work now either, windows says its all fine but no sound at all, It has the loudness option for onboard sound. When ms installed the default drivers it worked but i didnt have the realtek control panel then when i got the one from realtek's site it just stopped working again.
Cheers
08 Mar 2010   #5
Aphelion
Cheers
What is set as your default Input device? (for onboard sound)
Also, look to see if any of the Realtek outputs are muted.
Ap
08 Mar 2010   #6
hitman000
Heres a screener of playback devices.
Hope this helps.
Cheers
08 Mar 2010   #7
Aphelion
Hope this helps.
Cheers
Yep, but I asked what was your default Input (recording) device. If it's by any chance the Realtek digital audio device it should be set to an analog input.
If you right click in the Recoding window you can select "Show Disabled Devices" then select "Stereo Mix" as the default recording device.
This is one of the fixes for Realtek "no sound".
A digital input set as default expects to see an audio clock, when there is none it can sometimes (depending on the model) cut off the audio.
Ap
08 Mar 2010   #8
hitman000
When i set stereo mic as default device in recording devices the sound bar is fully green and still have no sound, also when i press mute it makes a pop sound when i mute or unmute & slider the volume slider. I dont understand how it can work with default ms drivers and not with ones downloaded from realtek. My mobo provider doesnt have any for windows 7. I can stick with my sb audigy but the low & loud problem is still there.
08 Mar 2010   #9
Aphelion
Explain the low & loud problem? Are you doing any online gaming or is this just in music playback.
Right click on the MS speaker icon, select playback devices, select the communications tab, Select "Do Nothing".
Don't know if MS forces the Creative drivers though part of the Win-7 audio subsystem or not. As you may have noticed, quite a few problems with Windows-7 audio.
Ap
08 Mar 2010   #10
hitman000
When i play a song on normal speed its fine, but when i adjust the play speed it sounds all messed up. Sorta like when the beat of the music starts it goes low then goes loud on vocals sorta thing. Its pretty weird, i have disabled the communications setting, no joy. Im stumped why my realtek wont work with its proper driver tho. But this low and lound problem happened on both sound chips with vista & 7. Its fine on windows xp. I thought it might of been media player.
Please note  Please note
        When your issue is fixed please remember to thank those that helped you and mark the thread as solved.
Laptop fan loud continuously loud, crashes later on
Hi Last night my device was perfectly fine, however when I woke up and turned it on this morning the fan was really loud and kept staying loud for long periods of time. Now it sometimes stays on for around 15 minutes but then "clicks" off. After that, I am not able to boot up for around 5-10...
Performance & Maintenance
xonar d2x sound card loud buzzing noise problem
I am using xonar d2x sound card and it has been good until recently when I played videos on youtube and games it gives a loud buzzing noise. Even sounds made by windows sound produces the loud buzzing noise. It also happens on sometimes when playing videos. Other than that it works fine. I tried to...
Problem sharing large files (Win7 <-> Win7)
Hi There, I got 2 PCs... A: Desktop PC, Windows 7 Professional 64-bit B: Media PC (connected to TV), Windows 7 Professional 32-bit I'm trying to share the files on my Dektop PC so i can access them from the Media PC. As it is a Media PC i'm sharing videos. I enabled sharing on the Folders...
Network & Sharing
mouse problem with loud noise
Hi I hope you can help me. Got a new computer a couple of months ago with HID-compliant mouse supplied (optical - sensor plugs in the back). Loaded in Windows 7 and for a couple of months everything was fine. Then yesterday, I was listening/watching a video when a continuous loud pitch...
Hardware & Devices
Windows 7 x64 volume too loud problem
Hi, I did not find any solutions to my problem from the forum so I decided to create a new thread about this. Problem details: -Volume is too loud, I have to set master volume to 1-5%, anything over that is too loud. I have had no problems when using windows vista or windows XP. My setup:...
