Windows 7: why this problem help very fast :/
28 Feb 2010   #1
sveetas
windows 7
windows 7 86x (32)bit help realtek Hight Definition Audio Driver no installed :/ where problem help Click this bar to view the full image.
and no find my sound plate
28 Feb 2010   #2
TheTeZ
Windows 7 -x6
do you have a CD that came with your motherboard? Maybe the drivers are on it. Otherwise look on the internet for drivers.
28 Feb 2010   #3
sveetas
windows 7
i have cd and instal cd realtek and this problem eror ? plz LINK for driver
28 Feb 2010   #4
FZ21Z
You'll get better help by filling your System Specs in properly, instead of making numerous threads on the same subject...
help no sound no install realtek
help no find driver or ??
https://www.sevenforums.com/drivers/6...g-problem.html
Have you visited the manufacturers website of your PC or laptop to see if there are any updates for whatever version of Windows 7 you may be running?
28 Feb 2010   #5
sveetas
windows 7
i dont speaking english men and no fix this problem :/
28 Feb 2010   #6
FZ21Z
Quote   Quote: Originally Posted by sveetas View Post
It's pointless us trying to help you then if you don't understand what we're saying to you.
FILL THIS IN - https://www.sevenforums.com/profile.php?do=extra
01 Mar 2010   #7
TheTeZ
Windows 7 -x6
Adobe Air update problem. Please help me I need fast answer
Today I received notification for new Adobe Air update and decide to install it . But the installation process was so slow and I just cancelled it. It was about 3 hours ago and the cancelling still is not finished. There is Adobe Air set up box on my screen that shows cancelling... So what to do?...
Software
Problem with Microphone (Disconnecting and reconnecting really fast)
https://i.gyazo.com/b3d44f341cc10c5a56244229a673f7d7.gif That's pretty much it, Although I did have an issue with the sound too but I fixed it when I installed VIA Hd Audio, I've never gotten my mic to work however. I'm using a headset (Turtle Beach X12) The mix definitely does work, I can...
My Win7 is booting too fast (and I have a funny problem with this)
After upgrade my laptop with a new SSD drive, my windows 7 is booting so fast, i have a little funny but weird problem: mouse/keyboard and external drive! When my Win7 is booting and my desktop appear, it's so fast that my usb mouse/keyboard (Logitech) and external drive take a while(10-15...
Hardware & Devices
is this fast?? also problem with line.
ok so i have adsl+2 internet broadband on an elite plan here is my results i want to know are these ADSL+2 speeds or just ADSL speed since we used to have that. results: Last Result: Download Speed: 9414 kbps (1176.8 KB/sec transfer rate) Upload Speed: 719 kbps (89.9 KB/sec transfer rate)...
Network & Sharing
.exe problem {Fast pls} :(
every time i open any program.exe it open ( open with.. window ) i cannot open any program ... and i cant open any repair program :S so what i can do
Software
