ZV6000 Audio x64 solved
For those of us who have been having a major head-ache with ZV6000 after updating to retail, or those of us who never had audio working on the x64 side ever, here is the final solution (provided below with edit for ZV6000):
Download the "Conexant AC97 Audio Driver for Microsoft Windows Vista (64-bit)" from http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-51288-1
installing it regularly didn't work but you can make a trick.
1. first, try to install it normally with the driver. it will probably fail but it will be extracted in C:\swsetup\SP35558 by default
2. open the .inf file and locate
[Conexant.NTamd64]
%*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD,PCI\VEN_1002&DEV_4370&SUBSYS_308B103C
%*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD_DF,PCI\VEN_1002&DEV_4370&SUBSYS_308E103C
3. add this line to it
%*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD,<x>
<x> can be found by going to the device manager, open the unrecognized audio device's property page, select "Details" tab, and select "Hardware Ids" from the Property combo. One of the listed strings should be <x>. it was the top one in my case.
In my ZV6000, <x> was PCI\VEN_1002&DEV_4370&SUBSYS_3085103C&REV_01
so it eventually looked like:
[Conexant.NTamd64]
%*WDM_AMCAUD.DeviceDesc%=WDM_AMCAUD,PCI\VEN_1002&DEV_4370&SUBSYS_3085103C&REV_01
4. now install the driver manually through device manager. It installed as "Conexant AC-Link Audio" which i find weird since it first was listed as "Conexant Realtec AC-97".
You should now have perfect audio. Note that for those updating from the various Realtec or ATI workarounds, the mute light also finally works again
If you are having trouble installing or it doesn't work after restart, remember that you need to "Disable driver signature enforcement" during boot (F8). You can also edit the boot using EasyBCD so that it will pop-up the menu for you and all you have to do is arrow up twice and select the option.
Cheers!
