Not reading sound card
  1. Posts : 4
    So, I recently upgraded from XP64 bit to Windows 7 32bit (Because 64bit sucks there's like no drivers for anything)
    Anyway, I noticed when i had things set up and went to Youtube it wasn't reading my sound. Eventually I went to Dxdiag to find out what soundcard I have, and turns out it doesn't even read I have it.
    It's a MSI motherboard, and my speakers are 5.1 logitech, I don't know nor can really find out any information besides this, I downloaded a device finder, but it couldn't see the soundcard either to search for drivers if it was a driver problem.
    So I'm not sure what to do other than buy another sound drive, which is kind of lame since this mother board costed me 300 bucks and I've only used it for a year.
    Is there any suggestions of what I can do.
  2. Posts : 3,822
    you won't see the soundcard in the actual DXdiag itself - but it will appear in the printout..
    did you save all information after doing the DXdiag, if so it will appear in the info produced..??
    the saved file will drop onto your desktop by default, and is readable via Notepad..
    BTW. there is no shortage of 64-Bit drivers..
  3. Posts : 28,845
    Win 8 Release candidate 8400
    You probably only need a driver. go into device manager (type device manager in search) look at the sound tab and see if there is a driver present and working properly.
    Let us know the results
    Ken
  4. Posts : 4
    Mmk
    Bug: Alright I'll check a print out, and I dunno if there is for Windows 7 64bit or not. However I know on XP64 my cam wouldn't work and there were no drivers that'd let it work, MSN 9 wouldn't load on it said it doesn't work for the OS and a couple of other things, it was to much hassle to trust Windows 64bit.
    ZigZag: I check, there was something that said "High Definition Audio Device" and says it's working properly.
  5. Posts : 3,822
    - could you post up the DXDiag printout, please
    - it might hold the necessary information to enable someone to trace the driver for you..
  6. Posts : 4
    System Information
    Time of this report: 3/6/2010, 19:34:18
           Machine name: FALCON-PC
       Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_gdr.091207-1941)
               Language: English (Regional Setting: English)
    System Manufacturer: INTELR
           System Model: AWRDACPI
                   BIOS: Phoenix - AwardBIOS v6.00PG
              Processor: Intel(R) Pentium(R) D CPU 3.40GHz (2 CPUs), ~3.4GHz
                 Memory: 2048MB RAM
    Available OS Memory: 2046MB RAM
              Page File: 1432MB used, 2660MB available
            Windows Dir: C:\Windows
        DirectX Version: DirectX 11
    DX Setup Parameters: Not found
       User DPI Setting: Using System DPI
     System DPI Setting: 96 DPI (100 percent)
        DWM DPI Scaling: Disabled
         DxDiag Version: 6.01.7600.16385 32bit Unicode
    DxDiag Notes
          Display Tab 1: No problems found.
            Sound Tab 1: No sound card was found.  If one is expected, you should install a sound driver provided by the hardware manufacturer.
              Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D:    0/4 (retail)
    DirectDraw:  0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay:  0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow:  0/6 (retail)
    Display Devices
              Card name: Radeon X1300 / X1550 Series (Microsoft Corporation - WDDM)
           Manufacturer: ATI Technologies Inc.
              Chip type:
               DAC type: Internal DAC(400MHz)
             Device Key: Enum\PCI\VEN_1002&DEV_7142&SUBSYS_070017EE&REV_00
         Display Memory: 1278 MB
       Dedicated Memory: 511 MB
          Shared Memory: 767 MB
           Current Mode: 1280 x 1024 (32 bit) (60Hz)
           Monitor Name: Generic PnP Monitor
          Monitor Model: AL1706
             Monitor Id: ACRAD46
            Native Mode: unknown
            Output Type: HD15
            Driver Name: atiumdag.dll,atiumdva.cap,atitmmxx
    Driver File Version: 8.14.0010.0630 (English)
         Driver Version: 8.56.1.15
            DDI Version: 9Ex
           Driver Model: WDDM 1.0
      Driver Attributes: Final Retail
       Driver Date/Size: 7/13/2009 17:14:55, 4030976 bytes
            WHQL Logo'd: Yes
        WHQL Date Stamp:
      Device Identifier: {D7B71EE2-3202-11CF-2876-0A27A1C2C535}
              Vendor ID: 0x1002
              Device ID: 0x7142
              SubSys ID: 0x070017EE
            Revision ID: 0x0000
     Driver Strong Name: atiilhag.inf:ATI.Mfg.NTx86...1:ati2mtag_RV515:8.56.1.15:pci\ven_1002&dev_7142
         Rank Of Driver: 00F42001
            Video Accel: ModeMPEG2_A ModeMPEG2_C
       Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
           D3D9 Overlay: Not Supported
                DXVA-HD: Not Supported
           DDraw Status: Enabled
             D3D Status: Enabled
             AGP Status: Enabled
    Sound Devices
                Description:
     Default Sound Playback: No
     Default Voice Playback: No
                Hardware ID:
            Manufacturer ID:
                 Product ID:
                       Type:
                Driver Name:
             Driver Version:
          Driver Attributes:
                WHQL Logo'd:
              Date and Size:
                Other Files:
            Driver Provider:
             HW Accel Level: Emulation Only
                  Cap Flags: 0x0
        Min/Max Sample Rate: 0, 0
    Static/Strm HW Mix Bufs: 0, 0
     Static/Strm HW 3D Bufs: 0, 0
                  HW Memory: 0
           Voice Management: No
     EAX(tm) 2.0 Listen/Src: No, No
       I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Sound Capture Devices
    DirectInput Devices
          Device Name: Mouse
             Attached: 1
        Controller ID: n/a
    Vendor/Product ID: n/a
            FF Driver: n/a
          Device Name: Keyboard
             Attached: 1
        Controller ID: n/a
            FF Driver: n/a
          Device Name: USB Keyboard
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x1241, 0x1603
            FF Driver: n/a
             Attached: 1
        Controller ID: 0x0
            FF Driver: n/a
    Poll w/ Interrupt: No
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x8086, 0x27CA
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 7/13/2009 15:52:09, 258560 bytes
    | Driver: usbd.sys, 7/13/2009 15:51:05, 5888 bytes
    Gameport Devices
    PS/2 Devices
    + HID Keyboard Device
    | Matching Device ID: hid_device_system_keyboard
    | Service: kbdhid
    | Driver: kbdhid.sys, 7/13/2009 15:45:09, 28160 bytes
    | Driver: kbdclass.sys, 7/13/2009 17:20:36, 42576 bytes
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    | Driver: i8042prt.sys, 7/13/2009 15:11:24, 80896 bytes
    + HID-compliant mouse
    | Vendor/Product ID: 0x1267, 0x0213
    | Matching Device ID: hid_device_system_mouse
    | Service: mouhid
    | Driver: mouhid.sys, 7/13/2009 15:45:08, 26112 bytes
    | Driver: mouclass.sys, 7/13/2009 17:20:44, 41552 bytes
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    | Driver: termdd.sys, 7/13/2009 17:19:10, 51776 bytes
    | Driver: sermouse.sys, 7/13/2009 15:45:08, 19968 bytes
    Disk & DVD/CD-ROM Drives
          Drive: C:
     Free Space: 48.9 GB
    Total Space: 114.5 GB
    File System: NTFS
          Model: WDC WD1200BB-00RDA0 ATA Device
          Drive: D:
          Model: PLEXTOR DVDR   PX-750A ATA Device
         Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/13/2009 15:11:26, 108544 bytes
    System Devices
         Name: Intel(R) ICH7 Family Ultra ATA Storage Controllers - 27DF
    Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_71761462&REV_01\3&2411E6FE&1&F9
       Driver: C:\Windows\system32\DRIVERS\intelide.sys, 6.01.7600.16385 (English), 7/13/2009 17:20:36, 15424 bytes
       Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 17:19:03, 42560 bytes
       Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 17:26:15, 21584 bytes
       Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/13/2009 17:26:15, 133200 bytes
         Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27C9
    Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_71761462&REV_01\3&2411E6FE&1&E9
       Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/13/2009 15:51:10, 24064 bytes
       Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 15:51:15, 284160 bytes
       Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/13/2009 15:52:09, 258560 bytes
         Name: RAID Controller
    Device ID: PCI\VEN_1106&DEV_3164&SUBSYS_71581462&REV_06\4&38303207&0&20F0
       Driver: n/a
         Name: Intel(R) N10/ICH7 Family SMBus Controller - 27DA
    Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_71761462&REV_01\3&2411E6FE&1&FB
       Driver: n/a
         Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27C8
    Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_71761462&REV_01\3&2411E6FE&1&E8
         Name: Radeon X1300 / X1550 Series Secondary (Microsoft Corporation - WDDM)
    Device ID: PCI\VEN_1002&DEV_7162&SUBSYS_070117EE&REV_00\4&81F6ADB&0&0108
       Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.0859 (English), 7/13/2009 14:09:17, 4194816 bytes
       Driver: C:\Windows\system32\DRIVERS\ativcaxx.cpa, 6/10/2009 13:19:15, 328162 bytes
       Driver: C:\Windows\system32\DRIVERS\ativcaxx.vp, 6/10/2009 13:19:15, 929 bytes
       Driver: C:\Windows\system32\DRIVERS\ativvpxx.vp, 6/10/2009 13:19:15, 52400 bytes
       Driver: C:\Windows\system32\DRIVERS\ativpkxx.vp, 6/10/2009 13:19:15, 2096 bytes
       Driver: C:\Windows\system32\DRIVERS\ativokxx.vp, 6/10/2009 13:19:15, 2096 bytes
       Driver: C:\Windows\system32\DRIVERS\ativdkxx.vp, 6/10/2009 13:19:15, 2096 bytes
       Driver: C:\Windows\system32\atiumdag.dll, 8.14.0010.0630 (English), 7/13/2009 17:14:55, 4030976 bytes
       Driver: C:\Windows\system32\atiumdva.dll, 7.14.0010.0208 (English), 7/13/2009 17:14:57, 4772352 bytes
       Driver: C:\Windows\system32\amdpcom32.dll, 7.14.0010.0018 (English), 7/13/2009 17:14:53, 50688 bytes
       Driver: C:\Windows\system32\atiumdva.cap, 6/10/2009 13:19:14, 69112 bytes
         Name: High Definition Audio Controller
    Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_176A1462&REV_01\3&2411E6FE&1&D8
       Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 15:50:56, 108544 bytes
         Name: Intel(R) N10/ICH7 Family Serial ATA Storage Controller - 27C0
    Device ID: PCI\VEN_8086&DEV_27C0&SUBSYS_71761462&REV_01\3&2411E6FE&1&FA
         Name: Radeon X1300 / X1550 Series (Microsoft Corporation - WDDM)
    Device ID: PCI\VEN_1002&DEV_7142&SUBSYS_070017EE&REV_00\4&81F6ADB&0&0008
         Name: Intel(R) N10/ICH7 Family PCI Express Root Port - 27D4
    Device ID: PCI\VEN_8086&DEV_27D4&SUBSYS_27D48086&REV_01\3&2411E6FE&1&E2
       Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 17:20:45, 153680 bytes
         Name: Intel(R) ICH7 Family LPC Interface Controller - 27B8
    Device ID: PCI\VEN_8086&DEV_27B8&SUBSYS_27B88086&REV_01\3&2411E6FE&1&F8
       Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 17:20:43, 13888 bytes
         Name: Intel(R) N10/ICH7 Family PCI Express Root Port - 27D0
    Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_27D08086&REV_01\3&2411E6FE&1&E0
         Name: Intel(R) 945G/GZ/GC/P/PL PCI Express Root Port - 2771
    Device ID: PCI\VEN_8086&DEV_2771&SUBSYS_00008086&REV_81\3&2411E6FE&1&08
         Name: Intel(R) N10/ICH7 Family USB2 Enhanced Host Controller - 27CC
    Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_71761462&REV_01\3&2411E6FE&1&EF
       Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/13/2009 15:51:14, 41472 bytes
         Name: Intel(R) 945G/GZ/GC/P/PL Processor to I/O Controller - 2770
    Device ID: PCI\VEN_8086&DEV_2770&SUBSYS_71761462&REV_81\3&2411E6FE&1&00
       Driver: n/a
         Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27CB
    Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_71761462&REV_01\3&2411E6FE&1&EB
         Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_244E8086&REV_E1\3&2411E6FE&1&F0
         Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27CA
    Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_71761462&REV_01\3&2411E6FE&1&EA
         Name: Intel(R) PRO/1000 PL Network Connection
    Device ID: PCI\VEN_8086&DEV_109A&SUBSYS_176C1462&REV_00\4&2A9E0036&0&00E2
       Driver: C:\Windows\system32\DRIVERS\e1e6032.sys, 9.13.0004.0010 (English), 7/13/2009 14:02:50, 211456 bytes
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
    DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
    Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
    AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
    CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16385
    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
    SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
    DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
    Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7600.16385
    Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
    Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
    VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
    File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
    iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
    iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
    DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
    Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
    Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7600.16385
    AVI Draw,0x00600064,9,1,quartz.dll,6.06.7600.16490
    RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
    WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
    SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
    Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7600.16385
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
    NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
    Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
    StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
    AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
    File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
    File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
    Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
    AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
    AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
    SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
    WDM Streaming Tee/Splitter Devices:
    Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
    WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
    GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
    Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7600.16490
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
    PBDA CP Filters:
    PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16385
    PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
    PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
    Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
    BDA Network Providers:
    Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
    Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16385
    Multi-Instance Capable VBI Codecs:
    BDA Transport Information Renderers:
    BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
    MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
    Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
    PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
    XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
    WDM Streaming Communication Transforms:
    Audio Renderers:
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
    EVR Power Information
    Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
      Quality Flags: 2576
        Enabled:
        Force throttling
        Allow half deinterlace
        Allow scaling
        Decode Power Usage: 100
      Balanced Flags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force half deinterlace
        Force scaling
        Decode Power Usage: 50
      PowerFlags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force scaling
        Decode Power Usage: 0
  7. Posts : 3,822
    Have you enabled the onboard sound in BIOS..??
    Your motherboard manual should tell you how to access the BIOS in order to change the settings that your computer uses when it boots up..
    - one of these settings relates to the onboard sound device
    Warning: do not mess around with the BIOS settings unless you are confident that you know exactly what you are doing..
  8. Posts : 4
    I'm screwed then my brother ended up throwing away my manual back a year ago X_X
    I've worked BIOS on 10 different pcs and they're all pretty simple and the same...Just hit the appropriate key during bootup (Delete, F10, F11, or something) and go into BIOS. You navigate around with the keyboard arrows and use enter to change the highlighted selection.
    In the BIOS, navigate to the tab that seems appropriate for your issue and browse through the options for motherboard sound devices. There shouldn't be too many.
    Make sure you can navigate to the EXIT tab and select "Exit and Discard Changes," or "Exit Without Saving," in case you think you screwed something up. Then you can just exit and not have screwed it up, because you won't have saved whatever changes you made!
  10. Posts : 3,822
    - have no fear, all is not lost.. :)
    - if you can ascertain the make and model number of your motherboard, it may be possible to find the motherboard manual online..
    just download and install this little (free!) program - it will provide you with a wealth of information about your system..
    CPUID
    to download, click on the link that I have highlighted on the site's page..
    if you look through the screenshots provided at the bottom of the same page, you'll soon learn how to use the program to find the necessary information..
