Sound has a little echo
My sound in Windows 7, windows media player, has a little echo.
It's like my speakers are at the bottom of a well.
Any idea on how to make the sound normal?
I have the newest drivers installed.
what soundcard are you using, or is it onboard..?
(ie. possibly Realtek?)
assuming it's a Realtek onboard sound device, check the manual at page 1 to see if you have any of the environmental effects in force..
http://www.gigabyte.com.tw/FileList/...00_0418-05.pdf
- some these settings may lead to an echo effect..
This didn't work for me. The problem was due to a poor ground connection on the stereo jack going to the speakers. This leads to the two stereo channels being added in anti-phase to each other which leads to an echo-like effect. You can prove whether of not you have this problem by moving the balance control to one side or the other when the echo should disappear. Alternatively try using headphones in the headphone socket. Cleaning the plug and socket (or in my case simply removing the plug and replacing it) cured the problem.
