Windows 7: Sound has a little echo
10 Mar 2010   #1
Dowser
My sound in Windows 7, windows media player, has a little echo.
It's like my speakers are at the bottom of a well.
Any idea on how to make the sound normal?
I have the newest drivers installed.
10 Mar 2010   #2
BugMeister
what soundcard are you using, or is it onboard..?
(ie. possibly Realtek?)
10 Mar 2010   #3
Dowser
Quote   Quote: Originally Posted by BugMeister View Post
There is no sound card. Everything is on the motherboard.
There might be a setting in Windows 7 to fix the echo but I can't find it.
Keith
11 Mar 2010   #4
BugMeister
assuming it's a Realtek onboard sound device, check the manual at page 1 to see if you have any of the environmental effects in force..
http://www.gigabyte.com.tw/FileList/...00_0418-05.pdf
- some these settings may lead to an echo effect..
11 Mar 2010   #5
Dowser
Thanks, I found the solution to the problem.
Change the Control Panel to: Sounds//Enhancements/none (was set to bathroom)
that fixed the problem
20 Apr 2012   #6
trythis
xp 32 bit
This didn't work for me. The problem was due to a poor ground connection on the stereo jack going to the speakers. This leads to the two stereo channels being added in anti-phase to each other which leads to an echo-like effect. You can prove whether of not you have this problem by moving the balance control to one side or the other when the echo should disappear. Alternatively try using headphones in the headphone socket. Cleaning the plug and socket (or in my case simply removing the plug and replacing it) cured the problem.
Annoying Echo Sound Every 40-60 Minutes?
For the past few weeks now this annoying echoy sound will play through my speakers every so often numerous times a day. Is there any way to track down certain sounds? Has anybody had this issue?
repeated echo loop sound on Windows 7
i am experiencing a repeated echo loop sound on my PC as i use Windows 7 and i don't know where else to look as i don't use a mic nor headset as i muted most of the sounds as i got 3 devices in Sounds speakers,Realtek Digital Output and Realtek Digital Output RCA i don't know on how they got in but...
Echo-y sound
On my new Windows 7 tower computer, when I plug in speakers or headphones, everything sounds like the bottom of a well. How can I get rid of that? (Realtek High Definition Audio) (Windows Home Premium SP 1) Thanks,
echo
when i listen to music or watch a movie, then the sound just echos... is the problem in my headphone because speakers are working fine..?
ECHO echo sounds
Hi My only poroblem with RC7100 revolves around the fact that through my speakers, when playing music, I get an "echo-ey" sound....I thought it was because I had placed my microphone too close to the speakers and/or had my microphone turned up too loud (no such problem when set up the same when...
