How to raise the volume, I recorded...
  1. Posts : 32
    Windows 7 Home Premium 64 Bit
    Im trying to record this sound clip using the sound recorder located under start/all programs/accessories and the sound clip that T recorded that is recorded off of a youtube video plays low, How do I raise the volume so that the recording can be listenable.
    Would Be Great Thanks...
  2. Posts : 13,354
    Windows 7 Professional x64
    If you have turned up your speaker volume, and it is still too quiet, you can amplify the sound clip using the free program Audacity.
  3. Posts : 32
    Would it make a difference if i do some adjustments under the sound manager??
  4. Posts : 13,354
    I'm not sure, I haven't ever used the sound recorder.
    Feel free to play around, but I highly doubt it has an amplify feature.
  5. Posts : 908
    You could try raising the record level.
    In Control Panel / Sound
    Select the "Recording Tab", you're probably using "Stereo Mix" as the default recording device. Select Stereo Mix and then select the "Properties" button.
    Select the "Levels" tab and raise the recording level to approx 80%.
    Make sure the volume output of the You Tube clip is full.
    If it's not loud enough you can try 100%, if that doesn't do it, download Audacity... for a free application it's an amazingly complete audio editor, anyone interested in audio on the PC can't go wrong by learning Audacity.
    Ap
  6. Posts : 32
    I tried raising up the recording volume. No change. Im probably gonna have to go with that link the guy provided above see how dat works. I remember on my winXP tower i didnt have to go through all this trouble lol. It recorded stuff nice and clear.
  7. Posts : 908
    I don't understand this... If you're using "Stereo Mix" as your recording device, raising the record level should affect the recorded audio. I just played a YouTube music video and could cut recording level to zero or raise it until the recorded audio moved into digital distortion.
    Ap
  8. Posts : 1
    win7
    hello
    i have same problem when i try record from sound recorder i try to record but signal is very low
  9. Posts : 13,354
    Welcome Dino!
    You can adjust the mic volume here:
