No sound from audio programs?
  1. Posts : 18
    Windows 7 64 bit
    I have a new windows 7 x64 PC, using an M-Audio Delta 1010LT sound card. I can get system sounds. When I try to open an audio program, such as EastWest virtual instruments or Cubase 5, I get no audio output. My settings appear to be correct within these programs. Any suggestions on how to fix this?
    Note: I updated to the correct windows 7 x64 drivers for M-Audio Delta already, and these programs are both compatible with x64.
    System specs:
    System Manufacturer/Model Number: Custom Build
    OS: Windows 7 64 bit
    CPU: Intel i7 860 2.8 GHz
    Motherboard: eVGA P55 (Intel P55 Chipset) (Supports SLi)
    Memory: CORSAIR DOMINATOR 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
    Graphics Card(s): eVGA GeForce 9600GT 512MB
    Sound Card: M-Audio Delta 1010LT
    Hard Drives: 1) 250GB SATA 7,200RPM w/ 16MB Cache
    2) 150GB 10,000 RPM 8MB Cache Western Digital Raptor
    3) 500GB WD 7200 RPM
    PSU: Corsair 750W
    Case: Antec 900
    Cooling: Maximum case fans
  2. Posts : 13,354
    Windows 7 Professional x64
    Welcome!
    Can Windows Media Player play sound? How about your web browser?
    You may want to confirm that the correct output device is set as default. Go to Control Panel>Sound and right-click on your speakers.
  3. Posts : 18
    Windows 7 64 bit
    I hear mouse clicks from the web browser, and one program I installed while setting up the system had music during the installation that was playing. I can't test out Windows Media Player right now because I'm at work...I will try when I get home.
  4. Posts : 908
    Windows 7 Home Premium
    I'm running an Audiophile 24/96 without problems, however, I'm not using it as the default audio device. The Audiophile is part of the Delta series and may even use the same driver, it's working fine with Cubase, Winamp...etc.
    Are you selecting the ASIO driver in East/West and Cubase?
    I'm wondering if using the 1010 as the default audio device is locking out the ASIO part of the driver?
    Ap
  5. Posts : 908
    Just remembered something... this could also be a MIDI/triggering problem, what interface are you using?
    Ap
  6. Posts : 18
    Windows 7 64 bit
    Thanks for the replies...I think it could be a MIDI/triggering issue, as within EastWest products, if I play a note, I see the mixer recognize the initial hit, but it wont hold out notes, and some notes are skipped. I just have an Axiom 61 midi keyboard plugged in via USB, and so far I've just been using the EastWest standalone VST and Cubase 5 to try to get sound. Any suggestions?
    I have the M-Audio Delta lines 7/8 (which I'm plugged into) as the selected device in EastWest...if I select M-Audio Delta ASIO from the list, I noticed that the latency times get much larger on the info boxes listed below. I'm not sure if its the default device...I'll have to check that tonight once I get home.
  7. Posts : 18
    Windows 7 64 bit
    Jonathan_King said:
    Welcome!
    Yes, Windows Media Player did play sound. So does my web browser. And the correct output was set as default in the control panel.
  8. Posts : 18
    Windows 7 64 bit
    Ap
    I think this might actually be a MIDI/triggering problem, did you have any more information on this?
  9. Posts : 18
    Windows 7 64 bit
    Nevermind...seems to be an issue only with EastWest's PLAY VSTs...I'll take it up with them, unless anyone here has any suggestions?
  10. Posts : 908
    Sorry for the late reply, I was gigging out of town for a couple of days.
    Did you get it working reliably in Cubase?
    Ap
