Windows 7: sound problem
05 Apr 2010   #11
Aphelion
Windows 7 Home Premium
Quote   Quote: Originally Posted by trogne View Post
Hello,
No more sound problem since I don't use hibernate or sleep.
But might this be fixed with a windows update someday?
Is there something I can try to fix it?
Thanks,
Patrick
I would hope so, a while back I noticed one of the Windows "optional" updates was related to fixing an audio problem afterthe computer comes out of sleep mode.
It looks like I installed it but have never tested it.
I'd gone through all of the optional installs and read the descriptions.
It could also be related to the driver itself but I'm betting it's a Windows problem.
Ap
21 May 2010   #12
trogne
Some windows update...
And still, my sound is always corrupted after a while back from sleep or hibernate mode.
My friend have the same laptop, and no problem.
Maybe it's because I once installed "SRS Audio Sandbox" and uninstall it then when I realized my laptop is already "SRS" (it's written "SRS Premium Sound" on my laptop skeaker).
But, I reinstalled my sound driver, and the problem is still there.
Any idea?
Thanks,
Patrick
30 May 2010   #13
trogne
Any help?
01 Jul 2010   #14
zeldaman1
win 7
hey, I discovered this problem when I installed 7 on my new laptop (new to me) I like to sleep to conserve battery and disabling it isn't an option. What I found is if you pause/stop your internet station/WMP before hibernating then it will play fine when you resume windows. (also, sorry for necro-post, I just found this problem irritating and went searching for an answer and found it myself, so I thought I'd share for everyone else
02 Jul 2010   #15
trogne
Thanks!
But what is "internet station"?
02 Jul 2010   #16
zeldaman1
win 7
like Pandora or last.fm
04 Jul 2010   #17
trogne
I don't use pandora or last.fm.
Now the problem gets back and haven't hibernated or sleeped.
 sound problem
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: https://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Sound Problem
I have tried to play mpegs and Avi files on Nero Showtime (Nero 7 ) and also on Divx 8, Realplayer and Quicktime but I get no sound. I do get sound on Win Media Player only. I installed Klite codec pack for Win 7 64bit. Do I have to install the 32bit codec pack for the 32bit programs to...
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
