USB digital sound input
Note: I've also posted this on the Goldwave Forum in case there is a Goldwave solution.
I've just switched to Windows 7 on a new PC. I own a phono pre-amp with both analogue line and digital USB output.
When I plug the pre-amp into the PC it installs as a "Microphone (USB Audio Codec)". Clicking Record starts at an absurdly high level, almost as if line input was plugged into a mic socket. So the Input Device volume has to be reduced to about 20% to get a sensible recording level.
With my previous PC (Windows XP), Goldwave recognized the USB device as a digital input and (I assume) took the bit stream straight into recording; there was no input volume level available, as I would expect.
But now it looks as if the USB input is being put through the PC sound card, converted to analogue and delivered to Goldwave whereupon it is re-digitized for recording.
If this is so it makes a mockery of trying to use a USB digital source. Should I be finding a different codec somewhere?
I'd appreciate any comments / ideas about this.
