Windows 7: Why Can't I Get 5.1 Sound On My Win 7 System! HELP!
04 Apr 2013   #31
aline1996
Tha Fix
hello everyone with this problem.
I know this is a Win 7 forum and I use Windows 8...
but if you search for windows 8 problems u'll end up here.
atm. the newest realtek driver is 2.70,
me myself use a 4.2 (5.1 with one speaker replaced with a subwoofer)
and when i installed the realtek drivers i still had stereo sound....
i went exploring and the solution:
its very simple open your Realtek HD Audio Manager > Speakers
then in the sub-tabs go to Sound Effects.
here you can choose an envoirement choose the most basic one "Room"
and there you go 5.1 sound :)
if you ever find this topic and you need some more help email me halo.aline@hotmail.nl
Regards Aline
04 Apr 2013   #32
Lady Fitzgerald
Win 7 Ultimate 64 bit
Quote   Quote: Originally Posted by aline1996 View Post
Regards Aline
I'm getting 5.1 (without center speaker; more on that in a minute) on my Logitech speakers using None in Environment so there must have been somethin g else going on with your system.
I have my center speaker disconnected because it responds both to output from the sub as well as the one for center and I can't the two separated. The problem is probably in the speakers since I had the same problem with my old XP system, but, then again, the old system also used Realtek.
04 Apr 2013   #33
aline1996
Quote   Quote: Originally Posted by Lady Fitzgerald View Post
i don't really know much about it yet my first pc with realtek and 5.1
but did you try to reconfigure your set as a 5.1?
04 Apr 2013   #34
Lady Fitzgerald
DUH! Yeah.
04 Apr 2013   #35
aline1996
hehehehe many people forget stupid lil things like that so that why i asked
i assume you have the drivers version 2.70?
then open the audio manager and try clicking swap center/ subwoofer what happens then?
also played with the full range options? might help
04 Apr 2013   #36
Lady Fitzgerald
Did all that. I'm almost certain the problem is with the speaker system.
04 Apr 2013   #37
Dude
Windows 10 Pro X64
Lady Fitzgerald, not sure if you tried this yet. I have a Logitech speaker setup and I tried all kinds of setup and driver things. Then low and behold I discovered my satellite speaker, the one with a headphone jack and power button has a tiny switch selector on the back of the speaker. I moved it and all of the sudden had surround sound.Hope that's a possible solution for you.
04 Apr 2013   #38
aline1996
lets hope so else: BUY A NEW ONE!
04 Apr 2013   #39
Lady Fitzgerald
Quote   Quote: Originally Posted by Dude View Post
...Did all that. I'm almost certain the problem is with the speaker system.
I don't know the model # of my 5.1 Logitech speakers (other than they are several years old and I have no desire to crawl under my desk to check the back of the amplifier/sub woofer enclosure; old age sucks) but none of the satellites have any switches on them. All the controls and the headphone jack are on a wired module that sets on my desk. The front and rear, left and right speakers work just fine. The problem is both the center speaker and the sub are getting the same feed. When I test the speaker connection in the Realtek driver, testing the center speaker feeds both the center speker and the sub. The same happens when testing the sub. I can't control the volume to the center speaker independently of the sub.
04 Apr 2013   #40
Lady Fitzgerald
Thank you! Do you want my mailing address so you can send me the money to pay for it?
Only sound from system, No oher software seem to trigger the sound
Hello again A new problem with my PC Win 7 64 pro No sound is heard from software like Excel. Sound issued by the system will be played I did open the sound Mixer and a click on the system icon will play a sound. A click on the 3 others will have no sound play.
changed sound card - now no system sound??
Greetings. Used onboard sound until today where I remounted my Auzentech X-Fi Forte. I have uninstalled the realtek sounddrivers and deactivated the onboard sound in BIOS. Everything is playing with the default analog speakers (5.1 setup) through the Forte, except systemsound (logon sound,...
Audiophile 2.1 sound system for Xonar D2X sound card.
I have given up on getting a good 5.1 or 7.1 sound system for my pc since it requires a receiver and all. What I am looking for right now is a 2.1 sound system that can be directly plugged in to my Asus Xonar D2X sound card. The system should have a really decent subwoofer with tight and deep...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
No digital sound out of external sound system
I have a GA-EX58-UD3R Rev 1.6 mobo in a PC connected to a Samsung PS63C7000 3D TV via HDMI and by Stereo Analogue, Coax and Optical to a Yamaha RX-V567 receiver/amplifier. The mobo runs the Realtek audio system supplied with the mobo, which has 5.1 Analogue outputs, coax and Optical out. On...
