Windows 7: Why Can't I Get 5.1 Sound On My Win 7 System! HELP!
04 Apr 2013   #41
Dude
Windows 10 Pro X64
Quote   Quote: Originally Posted by Lady Fitzgerald View Post
Quote   Quote: Originally Posted by Dude View Post
...Did all that. I'm almost certain the problem is with the speaker system.
Lady Fitzgerald, not sure if you tried this yet. I have a Logitech speaker setup and I tried all kinds of setup and driver things. Then low and behold I discovered my satellite speaker, the one with a headphone jack and power button has a tiny switch selector on the back of the speaker. I moved it and all of the sudden had surround sound.Hope that's a possible solution for you.
I don't know the model # of my 5.1 Logitech speakers (other than they are several years old and I have no desire to crawl under my desk to check the back of the amplifier/sub woofer enclosure; old age sucks) but none of the satellites have any switches on them. All the controls and the headphone jack are on a wired module that sets on my desk. The front and rear, left and right speakers work just fine. The problem is both the center speaker and the sub are getting the same feed. When I test the speaker connection in the Realtek driver, testing the center speaker feeds both the center speker and the sub. The same happens when testing the sub. I can't control the volume to the center speaker independently of the sub.
Okay we must have a different set as I don't remember my model number. I had the same problem on mine so I hoped it would help.
Quote   Quote: Originally Posted by aline1996 View Post
lets hope so else: BUY A NEW ONE!
Thank you! Do you want my mailing address so you can send me the money to pay for it?
She left her email so send it
05 Apr 2013   #42
aline1996
hehehehehe no.
Only sound from system, No oher software seem to trigger the sound
Hello again A new problem with my PC Win 7 64 pro No sound is heard from software like Excel. Sound issued by the system will be played I did open the sound Mixer and a click on the system icon will play a sound. A click on the 3 others will have no sound play.
changed sound card - now no system sound??
Greetings. Used onboard sound until today where I remounted my Auzentech X-Fi Forte. I have uninstalled the realtek sounddrivers and deactivated the onboard sound in BIOS. Everything is playing with the default analog speakers (5.1 setup) through the Forte, except systemsound (logon sound,...
Audiophile 2.1 sound system for Xonar D2X sound card.
I have given up on getting a good 5.1 or 7.1 sound system for my pc since it requires a receiver and all. What I am looking for right now is a 2.1 sound system that can be directly plugged in to my Asus Xonar D2X sound card. The system should have a really decent subwoofer with tight and deep...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
No digital sound out of external sound system
I have a GA-EX58-UD3R Rev 1.6 mobo in a PC connected to a Samsung PS63C7000 3D TV via HDMI and by Stereo Analogue, Coax and Optical to a Yamaha RX-V567 receiver/amplifier. The mobo runs the Realtek audio system supplied with the mobo, which has 5.1 Analogue outputs, coax and Optical out. On...
