Trying to get my audio to work!
  1. Posts : 189
    Windows 7 Ultimate 64bit
    i installed 7 on this older pc i have that was made with some different parts. im trying to get audio on this but i havnt had any luck.
    here is the pcs specs.
    windows7 32bit
    p4 2.4ghz
    512ram
    and here is the motherboard info:
    Manufacturer: ASUSTeK Computer INC.
    Model: P4T533
    Version: System Version
    Chipset vendor: Intel
    Chipset model: i850E
    Chipset revision: A3
    Southbridge vendor: Intel
    Southbridge model: 82801BA (ICH2)
    Southbridge revision: 04
    BIOS
    Brand: Award Software, Inc.
    Version: ASUS P4T533 ACPI BIOS Revision 1006
    Date: 03/14/2003
    are there any generic audio drivers that would work.
    anybody can help me thank you
  2. Posts : 14,606
    Hi and welcome to seven forums krispy1, do you have realtek HD audio software on your pc
  3. Posts : 189
    no i dont, just installed 7 on this pc today.
  4. Posts : 14,606
    ok ,i ask only as i have and have a little info on that , try this control panel/ troubleshooting under hardware and sound there is a troubleshoot audio playback link give that a whirl let us know how you get on
  5. Posts : 189
    trouble shooting doesnt help
  6. Posts : 908
    Windows 7 Home Premium
    windows7 32bit
    p4 2.4ghz
    512ram
    Model: P4T533
    Is it an Asus P4T533-C (is there a letter after the 533)
    The first or second search in Google shows that this board has a Realtek AL650 audio chipset.
    I thought Windows 7 supports that.
    Is the microsoft speaker icon in the Task Bar?
    Ap
  7. Posts : 189
    i solved the problem. i went to the asus site. had to do some digging then i found they still had driver support but only for 95,98,2000,xp. i knew that for some reason windows 2000 drivers sometimes work better with 7 with old hardware then xp drivers(i dont know why) so i downloaded the motherboard sound driver. then went threw device manager>update drivers then chose the drivers which i had placed in a folder on the desktop. windows 7 recognized the driver and installed the windows 2000 driver successfully and now the audio works
  8. Posts : 14,606
    good news :)
