Windows 7: No Audio help.
15 Apr 2010   #11
otakulou
Microsoft Windows Home Premium
Quote   Quote: Originally Posted by ryo View Post
can you capture your device manager? to see your driver is installed well or not.
Attachment 67368
Here is my screenshot.
15 Apr 2010   #12
si8mon
Windows 7 Ultimate 64 bit
Quote   Quote: Originally Posted by otakulou View Post
Attachment 67368
Right click the sound driver and select scan for hardware drivers. Post back your results.
15 Apr 2010   #13
otakulou
Alright I scanned it, nothing came up.....
15 Apr 2010   #14
si8mon
Have you updated the driver? I couldn't find the driver on the web so the only other way to update it is by right clicking it in device manager and selecting check for updates.
It could be a virus thats blocking your sound (but i don't think thats the cause). If you have a anti-virus scan your computer.
16 Apr 2010   #15
DarkStar GT
Windows Home Premium (64)
AFAIK, System Restore is reversible (as it is in XP.]
As a temporary diagnosis step, how about doing a System Restore to a time "more than 10 days ago". Check that the sound is still working. If it is, then some recent event has messed up the audio. If not then the problem is something more fundamental. But, whatever the result, undo the System Restore to bring you back to "today".
And what programs have you installed since that date?
16 Apr 2010   #16
ryo
oki i saw you have installed your driver.because that notif to the icon
try to /SFC SCANNOW
 No Audio help.
Suitable/Compatible Free Audio Driver for Dolby Advanced audio sound
I have a Lenovo Thinkpad E550 laptop with Windows 7. There are no enhancement features in the speakers properties section. I have realtek card reader...do I need realtek driver? I read that not all motherboards use realtek audio chips. What would be a suitable/compatible FRE audio driver to...
Drivers
Laptop audio problems possibly involving built in VIA High Def Audio
Hello I am new to this forum. I have searched for related problems here but did not find anything relevant, my apologies if this is a duplicate. What follows is a copy of a message sent to VIA (in Taiwan apparently): I seem to be having some issues with your VIA High Definition Audo drivers...
Drivers
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
