Does the Creative lab Xmod work on win7 32 bit
Before i buy this i need to kno if this would give me a problem on win7 32 bit
Help Plzzzzzzzzzzzzzz
I don't see why it wouldn't. Start from the product page (the bold bit is mine),
Seeing as it is supposed to work even when not connected to a computer I don't see why it wouldn't work with Windows 7.Works with PC, Mac and notebooks
Since the Xmod is truly plug and play, it just plugs in a works with Windows XP, Windows Vista and Mac OS X systems. If you don't want to use it with your PC, it even works standalone with an optional USB power adapter so you can get great Xtreme Fidelity sound from your MP3 player, TV or even your home theater.
