Misbehavior of sound system in window 7
  1. Posts : 24
    window 7 HOME PREMIUM
    Everyone i'm new to this forums,and this is my first post.
    I have HP PAVILLION DV 2000 which was window xp before,so i upgrade to windows 7 since then when ever my system goes in sleep mode,the sound disappears.I have to reboot the system to get the sound back.
    Is this normal characteristic of window 7 or any setting is required ?
    other thing is while using head phone,the sound comes from speakers too.
    I can't understand how to get rid of these two problems,any help would be appreciated thanks in advance.
  2. Posts : 28,845
    Win 8 Release candidate 8400
    You probably just need to go to HP and download the audio driver, and install it.
    Let us know if you need help
    Ken
  3. Posts : 908
    Windows 7 Home Premium
    Yes, it is a known problem.
    Microsoft had posted an -Optional- update that supposedly helped with this.
    Also, look in device manager and see what kind of built-in audio system your system has.
    Common types: Realtek, SIS, VIA, etc...
    Ap
  4. Posts : 97
    XP
    You just need to check out your Playback Settings. Set Default Communication Device.
    Here you can find very detailed instructions with pics, if you have trouble:
    How to Change the Default Playback & Recording Audio Device | Windows 7 Tutorials
    Good luck
  5. Posts : 24
    Thanks all of you guys.I tried the way you describe still no luck,problem remain same.
    Audio drivers are up to date,but which kind and make don't know.
    More help would be appreciated.thankyou once again to all.
  6. Posts : 908
    Did you go to Microsoft update and look through the optional updates?
    If you don't know what kind & make of audio driver then chances are they are not up to date.
    If you look in Device Manager under sound it will tell you the Make, also... launch System Info, that will also tell you the kind of audio device you have.
    Ap
  7. Posts : 24
    yes i performed optional updates too.
    I have audio driver from microsoft,which is showing upto date.
    still problem ramain same,has anyone sort out this kind of case?
    I need proper guidelines to solve the problem.Any help would be appreciated,thanks guys.
