Thank you, and do you want me to got to device manager, and update driver???
Yes. Expand the cab file to a folder on your desktop, update driver in device manager and browse to the driver. If it says the best driver is installed then force it. You can always roll it back later.
Well well this worked very well, and it made the volume buttons enbled again :)
Cheers all,
Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Hi
Its bit complicated.:D
I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
