Windows 7: No audio devices are installed. Please help.
27 Apr 2010   #11
JoshDavis
Windows 7 32 bit
Reinstall
Just reinstalled 7 without the SB Audigy. Started up and BING. HD Audio Device running fine in Device Manager and an HD Audio Device in Control Panel > Sound.
Sweet.
I'm a bit hesitant to try setting up the Audigy now because I'm so stoked right now to have sound that I'd hate to mess it up again so soon.
But if I was to attempt to get it working how should I go about it?
Disable Azalia Codecs, put the Audigy back in, download this driver:
Creative Sound Blaster audio driver 1.04.0090
Does that sound right?
I have the Audigy SE with the model number SB0570.
27 Apr 2010   #12
Aphelion
Windows 7 Home Premium
Quote   Quote: Originally Posted by JoshDavis View Post
Sweet.
Aha... so it was the Audigy drivers.
The 1.04.0090 driver looks like the right one, here's fair warning... The Audigy cards (I have one too) sound like crap under Win-7. The Realtek actually sounds better.
You can try it, but besides disabling the Azaila codec I'd also uninstall the Realtek drivers.
There are a couple of third party SB/Audigy solutions that sound pretty good, I've always been partial to the KX drivers, they sound great.
Official kX Project Site -- News
Keep us posted when you reinstall Windows again!
Ap
27 Apr 2010   #13
JoshDavis
Windows 7 32 bit
Thanks for all your help.
In that case I might just stick with the onboard. Sounds just as good to me.
Cheers for all your help. Trying everything that you suggested eventually led to working out what the problem was.
Thanks very much.
27 Apr 2010   #14
Aphelion
Thanks very much.
Hey, no problem... glad to be of help. Win-7 has been playing bad with audio for quite a few users. The Gigabyte motherboards seem to do pretty well, I had a bit of trouble at the beginning but all is well now. Updating the MB BIOS helped.
best-
Ap
No Audio Output Device Installed Error (Code 52 on my audio devices)
Hello there, I have an error in my Windows 7 with the audio, "No Audio Output Device Installed." I checked the playback & recording devices, but none are installed. I checked for hidden devices, but there wasn't any. So I opened the Device Manager, and checked the "Sound, video, and game...
Hey guys im new to this forum .I have a problem i dont have any sound.When i click on the volume icon at the bottom of my screen and go to playback it says ''No audio devices are installed''When i open the sound options there are no speakers. When i go to services.msc and try to start audio and...
No Audio Devices Installed, Help !~!
i recently change my windows from XP to windows 7. my VGA also change to a new one. when i test the sound, i cant hear at all !! i go to the contol panel, and check the sound, its say "No Audio Device Installed". i check again through the device manager, in sound,video it seem High Definition Audio...
Recording: no Audio devices are installed.
So i got a new headset and i found out that the sound works but not the mic. It works on other computers but not on my because it doesnt show up grey, it doesnt show up at all even thought i did check the show dissabled or disconnected devices. I tried to instal a new upgrade for my sound but the...
Hello. I need help. My computer is a Gateway Support - 1015229R*Gateway FX7024 Desktop Computer I had a misadventure with the original hard drive and bought a new one. Installed Vista on the new hard drive and got things going fine again except for the audio missing. I had installed...
