Windows 7: Problem with Audigy and optical IN
26 Apr 2010   #1
kykkus
Windows 7 64-bit
Hi, i have a problem, i have a sound blaster audiy platinum (1st series), windows 7 x64 and a tv with audio optical out.
I want to use optical IN of my audigy to listen the audio from tv to my 5.1 speaker of computer. The problem is that i can't hear the audio of tv and i don't know why. I try to go in: control_pannel-hardware_and_sounds-sounds-tab_recorder and i see that all of the name in the list are not ready, all but S/PDIF IN that is ready. The line next to S/PDIF IN (line that show the sound's level) is always gray, such as it don't receve audio.
Anyone can help me, please?
Sorry for my english.
26 Apr 2010   #2
maceman
Hi Kykkus,
One thing you could try is to update your drivers. Be sure that they're for 64.
If everything else is working, S/PDIF IN should work too..
27 Apr 2010   #3
fireberd
Are you sure you have an S/PDIF INPUT? Most of the cards in that era only have an S/PDIF OUTPUT from the PC.
28 Apr 2010   #4
kykkus
Windows 7 64-bit
thanks for reaplay, yes i have last driver and it is compatible with x64, and also yes the audigy have S/PDIF INPUT and also th S/PDIF OUTPUT...
29 Apr 2010   #5
maceman
Hi again Kykkus,
Just remembered..
Check out the Audigy's own mixer settings. Your S/PDIF may be muted there.
29 Apr 2010   #6
fireberd
I see S/PDIF I/O on the external "Audigy Drive" unit but not on the basic sound card. Is this what you have? I had a later Audigy 2 Platinum Ex model with the external "Audigy Drive" unit and it had the Optical I/O connections. Considering the age of this unit it could have malfunctioned and the reason the Optical no longer works. The Audigy Drive module in mine died and sadly I had to upgrade to a new model sound card as the Audigy line has been discontinued.
05 May 2010   #7
kykkus
Windows 7 64-bit
thanks for replay, the audigy mixer dosen't work in windows 7 i don't know what to do... i have audigy and in front of computer i have a pannel that is linked with audigy board, if i click on mixer audio of windows 7 (near clock) it show me: speakers, sound of system and S/PDIF IN, that have the highest level possible but wen i switch the monitor from monito to tv and set speakers exsternal i can't listen the audio and mixer of windows don show me the line where se the level of the audio such as there isn't audio...
05 May 2010   #8
fireberd
As I suspected you have the model with the "Audigy Drive". Considering the age of the unit it's not surprising that it's not 100% Windows 7 compatible. Your best option, to do what you want, is to upgrade to a new sound card that is fully Windows 7 compatible. The HT Omega Striker 7.1 sound card has both optical S/PDIF input and output and is Windows 7 compatible - both 32 bit and 64 bit. HT Omega - Striker7.1
Creative SB Audigy SE sound problem
Hi, I had a problem with my old sound card. It was not working at all. So i bought a new one Creative SB Audigy SE installed the drivers and everything that was given with the sound card and the sound is really weak. I have all the volume up to 100% everywhere and it''s playing music like it is 50%...
Creative SB Audigy 5/RX recording problem
Good evening. First of all I would like to thank you for accepting me to the forum! I have a Creative Soundblaster Audigy 5/rx and did a fresh install of Windows 7 Ultimate x64. Each time I boot my machine it seems that at random the Line-In and Microphone recording sources in the Windows...
Audigy 2 ZS and Microphone problem
Alright guys I am desperate, I have looked through countless websites, forums and advices. I recently added 2 Gigs of RAM to the 2 I already had in my computer running Windows 7 64bit. Once done, i found that my Microphone that was plugged in my Audigy 2 ZS sound card was making my voice sound...
Absurd Audio problem with Audigy 2 ZS
Hi all, I love this forum and I think this is the best place to have any info. Let's go to my annoying problem: Recently Windows 7 has been updated, and since that moment my audio went wrong. I can hear yeah, but the quality became worse than before, with a sort of cracking sound. However the...
SB Audigy 2 ZS Audio sound problem
i just installed win7 and i love it but sound sucks, i have SB Audigy 2 ZS Audio sound card, and i installed driver for it but my sound still sucks my problem is that i cant turn of 3D sound, i have stereo sennheiser headphones and when i play cod4 i only here on one speaker not the second one as...
