My speakers which is the realtek HD Audio Device is the default playback device
I guess you might want to check and make sure you're set to stereo output.
Same place where you see Speakers as the Default Playback Device. Select speakers and then use the "configure" button.
And your speakers are plugged into which color output jack?
Stereo is "light green" but for a few it seems to be black.
Also, you didn't by any chance disable some "services" recently.
Ap
I have been looking through the services trying to enable my Homegroup Listener but again to no avail, Windows Audio Service is running ok and the same with endpoint builder. what other services are vital for sound.
well Debley, im afraid this one has got me stumped , i will see if one of the forums sound experts have a better idea , bear with us a little while longer
So on Friday installed a new video card (7850) and this morning I had opened up the case as I have been experiencing some freezing with the new card (reason why I replaced the old card) however I have never had sound issues.
I did the following prior to leaving today:
Rebooted system a few...
Hi all,
I recently reinstalled Windows 7 on my laptop and since then the osund quality has been truly awful.
The specs are listed below, but I have un- and reinstalled the latest realtek drivers. The laptop was new when I wiped it so I don't know if the speakers are just terrible but it's a...
I think i need a driver update but i have no idea of where to get them or how to install them? any help would be great please!
ASUS® M4A785TD-V EVO: DUAL DDR3, S-ATA II, 2 x PCIe x16, 1 x PCIe x1, 3 x PCI
ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO
Windows 7 64-bit
Hi everyone, I'm running Windows 7 build 7000, and I have an ASUS P5P 800 motherboard that has an onboard sound device. After connecting to the internet, Windows Update installed 'Sound MAX Integrated Digital Audio' drivers, and the sound icon appears in the bottom right of the task bar.
The...
i installed windows 7 and after that everything works fine except that there is no sound. the device manager says that the HD audio is working fine. the driver is the updated version.
I don't know what to do. both the internal speakers and the headphones are not working. but the symbol for...
