Windows 7: Realtek HD Audio problem
05 May 2010   #11
danielprescott
it's genuine. The sound seems to crackle whenever I hover the mouse around. Gets particularly crackly whenever I play a high def video. The quality levels are all normal and if I go higher than cd quality it really makes a noise.
05 May 2010   #12
Onin
I got this problem too when i install the new update in realtek the sounds crackle :S help please.
06 May 2010   #13
danielprescott
sorted it. I got the last realtek driver before 7 was released. Probably the driver I was running before I upgraded. :)
Problem with High Definition Audio - Realtek HD Audio - Code
Hi, I have several computers of differents (HP, Toshiba, etc) and It happens the same problem. The audio device has an exclamation mark in Device Manager. I think this problem is caused by some update windows. My OS is Windows 7 Home Premium 32bits . Does anyone know what Windows Update...
Realtek HD Audio has a driver problem
Hi folks, I've been having a problem with audio output on my computer for a couple of days now (I specify output because my microphone seems to be working just fine). Anyway, the overall problem here is that there's no sound; I check the properties for Realtek HD Audio in Device Manager and see...
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Problem with Realtek HD Audio
Hi guys, hope someone can help me. I just installed Windows 7 Professional on Acer aspire m1610 which using SIS672 chipset and built in Realtek HD audio. The latest driver from realtek is R2.41 for vista & 7. So I downloaded it and install.But there's some problem when playing music or sound.It...
Realtek ac 97 audio problem... help!
Realtek ac 97 audio is what the motherboard disk has on it. i've tried to vista and xp driver on the disk, but doesn't work. i've tried to download a windows 7 driver from this forum and it doesn't work... wondering if vista and win 7 drivers are similiar. i can't connect to the internet...
