Volume Controls in full screen applications
  1. Posts : 9
    windows 7
    Hi i am able to use my logitech internet navigator keyboard to adjust the volume on the desk top or really any thing thats not full screen but the second that i switch to full screen such as on youtube or a video game i am unable to adjust the volume until i alt tab out to do so if any one knows the solution to this problem would be greatly appriated im out of ideas
  2. Posts : 6,879
    Win 7 Ultimate x64
    Could be due to the keyboard using the default Windows keyboard driver, that and as far as a Logitech driver goes it uses the older iTouch which isn't supported under Windows 7. There is one thing you can try and that is Setpoint,
    Download SetPoint 4.80 - FileHippo.com
    and see if it will recognize and work with your keyboard. If it does that should get your volume keys working, as well as allowing you to use the rest of the extra function keys that may not be working.
    The above is for the previous version (4.8) as the latest (6.0) has a tendency to be buggy even on mice and keyboards that support it. It is also for the 32 bit version and if you need the 64 bit version, let me know and I can upload it for you.
  3. Posts : 9
    windows 7
    nope
    this key boards designed to work on itouch how ever i did try the set point 4.8 any how did not recognize the keyboard was a good try does any one know a way of adding drivers to set point to add functionality back to a keyboard that is still perfectly good?
  4. Posts : 6,879
    Win 7 Ultimate x64
    Setpoint was a long shot as it is hit and miss as to whether it will work with unsupported mice and keyboards. Did find this on the Logitech forums,
    iTouch and MouseWare fix for Vista and Windows 7 - Logitech Forums
    where it appears that iTouch can be made to work.
  5. Posts : 9
    windows 7
    worked
    that one worked thank you
  6. Posts : 6,879
    Win 7 Ultimate x64
    You're welcome and thanks for posting back.
