My sound is Screehcy and inaudiable
  1. Posts : 2
    Windows 7 Pro x64
    Hey there,
    Im not too technical so its been hard for me to identify the problem, all i can say is that whenever my computer plays any kind of sound it is screechy, distorted and ear peircing. i have no idea of the source of the issue at all.
    the same problem occours no matter the out put be it headphones or speakers, teh problem still occours when I plug the output device into the secondary plug.
    It occoured randomly while streaming music.
    I use the windows default audio driver (PnP audio) and have tried unintalling and letting windows update reinstall, but to no avail.
    The soundcard i beleive is intergrated to my Asus M2N SLI-E mother board, if that helps
    any light shed on this would be very grateful,
    Thanks.
  2. Posts : 28,845
    Win 8 Release candidate 8400
    AlmightyHam said:
    Hey there,
    Thanks.
    It is probably as simple as a driver. You can get the drivers here. ASUSTeK Computer Inc.-Support-
    Let us know if you need help
    Ken
  3. Posts : 2
    Windows 7 Pro x64
    ive checked for that, however Asus no longer produce drivers for this MB. as its old accourding to The AsusTek Forums
    "This motherboard is from 2006 = OLD = STONEage, so don't expect anymore updates from Asus!"
    not offcial but the last update was a few years back.
    There are not even Windows7 Specific drivers as an OS option.
    aftr reading a few suggestions in multiple posts over there, sounds like a poor motherboard in the first place, tempted to just buy a new one after checking for compatibilty with everything else.
    Thanks.
    (also my apologies its the M2N-E SLI)
